Oursdur
Hi and welcome. this dump was caused by usbuchi.sys which is part of the Microsoft USB miniport driver. I noticed 2 things first you have SP1 not two that in itself would help, and two the date on this driver is somewhat old. I would suggest Re-installing the usb driver and upgrading to sp2. If you have a backup that you can restore from that would also be a work around. Another workaround is to run the system file checker (SFC /scannow) to see if ther are any errors
Good luck
Ken
Hi Ken
Not sure where my last post went since I can't see it here :huh:
In the meantime still I did a sfc/scannow and it came with a good result (no integrity violations found).
How can I find which USB driver requires update, since there are many different ones under the device manager/USB controllers?
Thanks
PS I am running Ultimate 64bit SP2 on that machine even if the machine to post this message is on Vista Business SP1.
- Dell Latitude E6500
- Intel Core Duo CPU T9800 @2.93GHZ
- 8 Gb
- Nvidia Quadro NVS 160M
- Dell E207WFP
- 1680 x 1050
- 250 gb
- Slow !
