Blekko in stead if IE?
Just had a thought.
When you pick a destination in Macrium, dont type it in. Use the browse function. It does not say browse. You will see a very small square box, just click on it. You will see a list of all the possible destinations.
I was typing as you were doing the same. After you are done verify the image. This will make sure that it is done correctly. You will see verify in the Macrium Software.
Rich, I think it's working!!!!!!!! Eurica. I'm writing this from yy IPad, hope you get it. It looks like its working, I typed F:/ as was listed and it's busily "Saving". I'm just going to sit back until it finishes. Anything I need to do after the saving is all done? Can't thank you enough Rich, you are giving me the confidence to have a go. I will be back.
After you are done we will verify that is it done correctly
and then
We will download Karens replicator to make a back up of your stuff. You will like Karens software.
Karen's Replicator
Your doing great, buddy.
All the members that help out at the forum are volunteers. We get our satisfaction from knowing that those that we help appreciate our efforts. You my friend have given me more appreciation than I deserve.
Im going out to Dinner soon, but I think you are pretty well set. Any problems or questions, just post. I promise you will not be forgotten.
Again IChat, thanks, enjoy your dinner, you earned it! I think I'm good now but if anything goes wrong I will post. Just a quickie......should I leave the drive plugged in all the time?
We are not done, download the Karens replicator and try to figure out how to back up your stuff. After that is done, set it to do it automaticlly, per a schedule.
Then you can shut off your HD, but be sure its on when Karens is going to back up your stuff, or you can back it up manually with Karens.
When you shut it off, use the short cut that I gave you a few posts ago.
Glad that we could be here for you.
First crisis....... I have with a keystroke deleted all my email files and folders. Anyway to retrieve them from my back up on the external drive? Tried myself but afraid to do more damage......
