Solved Black screen in IE, fonts...
Any one that posts due to my request will post in this thread, just keep your eyes opened. Thanks for your appreciation.
Hi Chewey.
Are you still able to login?
I will give you my personal fonts, but they are for windows 7; not that there should be a difference.
I will only give you the english and french fonts at the moment since they are too large to post, unless you have a specific language in mind.
EDIT: I actually might be able to extract the fonts folder out of my vista installation .iso file, if it has to be specific.
    HP Pavilion G6
    750GB HDD 6GB RAM
    AMD A6-3400M APU with Radeon HD Graphics
    25mbps
I don't use Vista, but can you navigate to Control Panel\All Control Panel Items\Fonts\Font settings? Then click Restore default font settings.
Many free fonts are available here:http://www.dafont.com/
    Custom desktop
    Intel i5-2550K
    ASUS P8Z68-V PRO GEN3
    16GB G.Skill Sniper, 2133MHz
    ASUS nVIDIA GTX460
    realtek onboard
    Samsung P2570HD 1920X1080
    Crucial M4 128GB Os drive, Seagate Constellation 500GB, data
    Corsair HX650
    Inwin Dragon Rider w/custom made side window
    Hyper EVO with 2 Noctua fans, 140mm, 120mm, 4 case fans
    Cat!
    some old Dell USB
    BluRay-RE, CD/DVD-RW, USB 3.0 front panel, card reader
Could you ask the brothers girlfriend what happened before this problem started?
Did you try creating a new user account and see if it looks the same? Here's a tutorial on how to do that: http://www.vistax64.com/tutorials/93009-user-account-create.html
You could also try uninstalling Kaspersky and replace with MSE which you can download from here: Download Security Essentials 4.0.1526 Vista - FileHippo.com
Sorry if I've missed it, but does the SFC scannow revert with violations or is it clean? Try it 2 more times.
You may also want to do a clean boot: Troubleshoot Application Conflicts by Performing a Clean Startup - Windows 7 Forums
By the way, what are the specs of this pc? Is it up to date?
Download and install speccy from here Download Speccy 1.17.340 - FileHippo.com and let us know the specs on your next post.
Will be waiting.
KK
Thanks for everyone's help!
Windows8--> That would be awesome, thanks. I don't even need French... just English please.
Britton30--> Nope. There is no "Font Settings" in Vista. Already checked. Thanks.
koolkat77--> In answer to all your questions.... She doesn't know. Her kids use the computer all the time, very young kids. So asking them is just as good as ... well, not asking them. Creating a new accont sounds like a good idea, I may give that a try. And oh, that's another thing - Kaspersky fonts are all screwed up even worse than the browswers! That's why I really think its a font problem. And, I tried sfc /scannow 3 times now and still issue still the same. Its a newer PC, not state of the art (heck, it has Vista....) so .... that should tell ya something. I will also try Speccy soon, I really want to try the fonts thing. Hey.... If Windows 7 fonts are the same as Vista, I may be able to do it myself - i have 2 Windows 7 computers and 2 XP computers in the house other than that Vista one.
THANK YOU EVERYONE!!!!!!!! PROBLEM SOLVED!!!!!!!!!!!
I copied my entire fonts directory from the Windows 7 laptop to my brother's Vista desktop, AND - it works. Perfectly. THANK YOU THANK YOU THANK YOU THANK YOU THANK YOU THANK YOU THANK YOU THANK YOU THANK YOU THANK YOU THANK YOU THANK YOU THANK YOU THANK YOU THANK YOU THANK YOU THANK YOU THANK YOU THANK YOU THANK YOU THANK YOU THANK YOU THANK YOU THANK YOU THANK YOU THANK YOU THANK YOU THANK YOU THANK YOU THANK YOU THANK YOU THANK YOU THANK YOU THANK YOU THANK YOU THANK YOU THANK YOU THANK YOU THANK YOU THANK YOU THANK YOU THANK YOU THANK YOU ALL!
Everyone who has helped share in your happiness. Now make that image and the next time you return, it will be to have fun and not because you have problems.
Good going my friend.
When you download Macrium get familiar with the site, you can burn a cd. I find that the burn function does not seem to work properly and I use the ISO procedure.
But, to answer your question yes and I think that its essential to have. I actually needed it, myself. Installing updates, I froze and had to turn the computer off the wrong way. I could no longer boot. I used the CD and I was back like new.
Imaging with free Macrium - Windows 7 Forums
I'm glad you got it all sorted out :-)
    HP Pavilion G6
    750GB HDD 6GB RAM
    25mbps
And I thank you for taking the time to help.
You are a new member, but you are so correct. We act as a family to help anyone who needs us. In addition, we can be a lot of fun, too. Stop by to learn or just have fun.
As I understand it, you're going to copy the fonts from Win 7 to Vista.
    Vista Home Premium 64 bit SP2
    Cyberpower
    Intel Quad CPU Q6700 2.67 GHZ
    NVIDIA 780i
    MSI GTX 560 TI Twin Frozr
    Sound Blaster SB Audigy
    Viewsonic VG2436
    1920x1080p
    Samsung HD 105SI WDC WD20
    Apevia XJupiter
    air
    Logitech MX 600
    Logitech MX 3200
    30 Mbps
@wither he already did that and it fixed his problem.
    HP Pavilion G6
    750GB HDD 6GB RAM
    25mbps
Oops. :sick: I didn't go back far enough to see that he had mentioned that in this thread. I only saw it in his other thread. Didn't want to leave it open-ended.
    Cyberpower
    NVIDIA 780i
    Viewsonic VG2436
    1920x1080p
    Apevia XJupiter
    air
    Logitech MX 600
    Logitech MX 3200
    30 Mbps
