Solved AVS Audio Converter
I have now totally uninstalled the suite;
i deleted the AVS4YOU folder in program files
i then ran CCleaner, and deleted EVERYTHING it flagged up about the registry or applications and it now says there is no unnecessary objects on my computer, whether in applications or registry.
i then rebooted and went into regedit.
entries still appear to be there for AVS
any ideas...?
or should i just re-install the suite and see if the problem is resolved
    Advent 9515
    AMD Turion 64X2 2.0GHz
    2GB
    ATI Radeon X1250
    Should be 10Mbps, often less
    Build #1
    Intel Core i7 3770K @4.4GHz
    ASUS P8Z77-V PRO
    Integrated on motherboard
    23" LG LCD/LED IPS
    1920*1080
    NZXT Phantom 410
Wow! The problem appears resolved, now I can convert without losing the tags and album art like all the other programs I use.
Tom, If you weren't in my last 15 top people I would definitely give you some rep
Thankyou so much
Macca
    Advent 9515
    2GB
    ATI Radeon X1250
Thankyou so much
Macca
No problem, glad that I could help, people should be rewarded by the feeling of being able to have helped someone, not rep :)
Perhaps you can help me out? I'm looking to convert all 8000 songs of my music library to mp3 to put on my xbox but the software that I have tried so far doesn't keep the id3 tags (album name, artist etc.). Does AVS keep all of these details like you said? And can it do batch conversions?
Tom
    Build #1
    ASUS P8Z77-V PRO
    23" LG LCD/LED IPS
    1920*1080
    NZXT Phantom 410
I sure can.
I convert using AVS from iTunes to mp3 to put on my phone. It keeps all the tags and the album art and you can even edit them before conversion. I am really pleased with all their software, theres loads of options for audio conversion and it is really well priced, and worth it for the unlimited subscription as you get all the updates and new releases.
and it does a decent selection of formats and the useful "import from video button"...
Also, for tag editing, I recommend mp3tag
Hope that helps
macca
    Advent 9515
    2GB
    ATI Radeon X1250
I sure can.
Hope that helps
macca
Wow, thanks for all of the information it was far more than I was expecting :) I'll download it now and use it as a trial and if I like it, I'll buy a license. Thanks for all of the information macca, I really appreciate it
Tom
    Build #1
    ASUS P8Z77-V PRO
    23" LG LCD/LED IPS
    1920*1080
    NZXT Phantom 410
it is no problem at all, glad to be of help
    Advent 9515
    2GB
    ATI Radeon X1250
