Thank you for you info. When i went in to ati CCC i looked at the hardware tab and it was blank maybe the driver was getting installed with errors, i wiped everything rebooted and installed 7.12 rebooted again and hooked up both cards everything works YAY.
I have one more questions i sound like such a noob but well i am when it comes to crossfire. I get slightly worse performance in crysis v1.1 and lord of the rings online when crossfire is enabled. all my other games run great but its hard to tell since i was able to run everything else on max with my x1950xtx before i upgraded. Do you think those hotfix's will help. What can cause the drop in performance or no performance gain???
P.S. My mobo was a ati xpress 3200 which was renamed to current 580x from all the info i can find it's supposed to be crossfire X capable, it's the same board ati uses in there animation thing for explaining how crossfire works. so my point is..... shouldn't i be getting the most performance possible from these two cards???
It really depends. The hotfixes are going to help, or at least not hurt. I know there were some fixes out for the Crysis issues, which I think are covered in that link I sent you. A quick google search on it might help. I don't have Crysis, so I don't know much about what to tell you. This thread might provide some insight to you, though it looks like Crysis is still having multi-GPU issues: AMD Game Forums - Crossfire boosted in Crysis patch 1.1 DX10.
As for performance, like I said, it depends. Some of it comes down to how good the coding for the program was. Also, it will depend on how good the Crossfire profile is. You should get better performance, but there are certainly times where it doesn't give better performance (though it won't often get worse, unless the coding is terrible).
Watch for Catalyst 8.1. Should be out by the end of this week, I'd guess. Maybe beginning of next week. Either way, it'll be that much more important for you to keep the drivers updated now that you have Crossfire (I'd recommend staying away from betas, though).
