Api_index_mismatc bsod need help!
Hello i have been getting API_INDEX_MISMATCH when i am reaching over 2gb of ram. I have done hard drive tests and ram tests and no problems. Im starting to think its a driver issue but i cant find it. Some one please give me a program to list my PC stats i forgot the one i use to use. This is on my desktop not laptop btw
    Custom built Desktop
    AMD Phenom II X6 1090T Black Edition 3.2Ghz
    MSI 890FXA-GD70 AM3 AMD 890FX
    8GB Adata Gaming series 2.0 DDR3 1600
    MSI Twin Frozr 5830 X2 with MSI 5850 Crossfired
    Asus 19", Acer 17"
    1400x900
    OCZ Agility 3 60gb, 500GB F3 Samsung Spin point and 5 other HDD's
    850W OCZ
    NZXT Phantom
    2 200mm fans with 6 120mm fans
    Logitec G9
    Saitek 2
    Major AMD, ATI and MSI Enthusiast.
Check your RAM voltage. All newer RAM DDR2 DDR3 have voltages of 1.9-2.5v if the voltage is not set right on the RAM you will always get BSOD. I had the same problem after building this PC.
    Powered By Asus Built By Me
    AMD Athlon II 250 Regor 3.0GHz
    AsusTek M3A76-CM
    2x 2048MB DDR2 PC6400 OCZ High Performance Gold Edition @ 2.1v
    ECS Geforce GTS 250 512MB
    Via Onboard
    Acer X203H Compaq FS740
    Acer-1600x900 Compaq 1280x1024
    Seagate Barracuda 250GB 7200 RPM Western Digital Caviar 80 GB 7200 RPM
    A-Power 680 Watt PSU
    Power Up Micro ATX Case
    1x 120mm Case Fan 1x 80mm Case Fan
    OCZ Equalizer 7 Button Laser Gaming Mouse
    Microsoft Comfort Curve Ergonomic Keyboard
    6Mbps
    1x 1024 PNY Flash Drive Integrated In Windows ReadyBoost.
Ok ill check that but I did not modify them only thing I have done latly is instal windows 7 64 bit from windows xp 32 bit
    Asus 19", Acer 17"
    1400x900
    850W OCZ
    NZXT Phantom
    Logitec G9
    Saitek 2
when you installed windows 7 x64 from windows xp did you do an upgrade or complete format? If you did an upgrade do a complete format.
    AsusTek M3A76-CM
    Via Onboard
    6Mbps
Comeplete format I bought it OEM to save cash
    Asus 19", Acer 17"
    1400x900
    850W OCZ
    NZXT Phantom
    Logitec G9
    Saitek 2
are you running Norton antivirus?
    AsusTek M3A76-CM
    Via Onboard
    6Mbps
    Asus 19", Acer 17"
    1400x900
    850W OCZ
    NZXT Phantom
    Logitec G9
    Saitek 2
whats the brand of your ram so i can check the specs of it?
and is this for a desktop or laptop?
    AsusTek M3A76-CM
    Via Onboard
    6Mbps
It is kingston 1024 mb ddr2 800. On my bios they are running at 667 and running at speeds 5559 duel chaneled
    Asus 19", Acer 17"
    1400x900
    850W OCZ
    NZXT Phantom
    Logitec G9
    Saitek 2
i am currently trying to figure out how to get windows debugger working i am downloading symbols now. Any suggestions on this i am looking for my .dmp files but i cant find them.
    Asus 19", Acer 17"
    1400x900
    850W OCZ
    NZXT Phantom
    Logitec G9
    Saitek 2
Ok i was looking at some forums and found STOP 0x00000001, 0X0000001, APC_INDEX_MISMATCH
it says this on 10. Too much RAM (> 2GB) may exceed motherboard and BIOS capabilities and create this STOP Error.
which explains it. could that have been it? i reinstalled my bios and ran 10 wow clients reaching 3.5gb of ram used no crashes
    Asus 19", Acer 17"
    1400x900
    850W OCZ
    NZXT Phantom
    Logitec G9
    Saitek 2
IDK if i fixed it yet but for the last few while i have been noticing some lag and hangs any idea what could be causing that? it might be the same issue
    Asus 19", Acer 17"
    1400x900
    850W OCZ
    NZXT Phantom
    Logitec G9
    Saitek 2
That i do not know about. Could be too much stuff running in the background?
Processor usage should be from 0%-25% at all times.
    AsusTek M3A76-CM
    Via Onboard
    6Mbps
This is the path you need to access the symbols.
Open the debugger as administrator, go to File > Symbol File Path > and enter this (copy and paste) http://msdl.microsoft.com/download/symbols
When you download the symbols and install, they should go to the default location Windows Symbols.
Hope this helps.
    Self Build
    Asus P5Q Premium
    2 x ASUS EAH 4870 X 2 (Quad)
    Supreme FX 2
    CoolerMaster 1000
    Logitech G5
    Logitech G15
    20Mbps
You will find your minidump files in C > Windows > minidump > if you want to upload them, zip them up and upload them with your next post, you may need to move them to your desktop first.
    Self Build
    Asus P5Q Premium
    Supreme FX 2
    CoolerMaster 1000
    Logitech G5
    Logitech G15
    20Mbps
That folder is empty
    Asus 19", Acer 17"
    1400x900
    850W OCZ
    NZXT Phantom
    Logitec G9
    Saitek 2
um im missing the wbconfig.reg file or the windows backup registry file on my PC can some one give me the right name for it so i can download it or u guys can give me a copy? some reason when i reformat my laptop its always missing.
    Asus 19", Acer 17"
    1400x900
    850W OCZ
    NZXT Phantom
    Logitec G9
    Saitek 2
To set your system to record minidumps follow this.
1. Right click computer.
2. choose Advanced System Settings.
3. Go to Startup and recovery.
These are the default settings.
Hope this helps, good luck.
    Self Build
    Asus P5Q Premium
    Supreme FX 2
    CoolerMaster 1000
    Logitech G5
    Logitech G15
    20Mbps
Here are my memory dump files the major one im having issues is APC_INDEX_MISMATCH can some one look at them and tell me what is the issue? im not good at this
there was a NTSF one on there probably cause i was trying to backup my laptop on my network to my desktop and it gave me BOSD too. but major issue atm is the APC one
    Asus 19", Acer 17"
    1400x900
    850W OCZ
    NZXT Phantom
    Logitec G9
    Saitek 2
If you have any part of your system overclocked, please set it to default. (until the problem is fixed).
NTFS was the cause of the first four dump files, this can be caused by,
"Disk corruption, insufficient physical memory, Device driver, Indexing, Resident antivirus, backup, defrag programs, Disk/Drive failing/failure"
The last one was the APC_INDEX_MISMATCH, the question is, did one cause the other.
I would start by removing any third party defrag and AV software.
Then run a full file check. http://www.vistax64.com/tutorials/181765-elevated-command-prompt.html, sfc /scannow.
Next, go to your HDD manufacturers site and download the test software for your HDD and run it. If you have another HDD that you are sure is good, then try that.
Also, just to eliminate any driver issues, follow this link. Please read the whole article before proceeding.
How to identify a buggy device driver on Windows Vista | Vista Rewired
Hope this helps, good luck and post your results.
    Self Build
    Asus P5Q Premium
    Supreme FX 2
    CoolerMaster 1000
    Logitech G5
    Logitech G15
    20Mbps
