Another 4gb Vista 64bit problem
Ok, maybe I should have been more clear. In my experience, Vista x64 doesn't work without that patch if you have 4GB+ of memory.
I have done clean install of Vista 64 Ultimate with 4GB and all 4 slots populated....
No BSOD..... Maybe some motherboard have problems, and some don't.
    Q6600
    MSI P36 NEO2
    4GB 5-5-5-12
    8800GTS 512Mb Overclocked
    5.1 surround sound
    500Gb Samsung SATAII XP 500GB Samsung SATAII
    1000W CoolerMaster power supply
    CoolerMaster Cosmos 1000 case
    120mm ThermalTake Big Typhoon CPU cooler, 3 x 120mm exhaust
    Wireless Keyboard and mouse 3000
    1TB WD My Book Office edition external drive x 2, Dual layer LG DVD-Rom burner, 15 in 1 card reader Triple boot: XP, Vista Ultimate 64 and Windows 7 Ultimate 64
I think I might have fixed it.
I was using the purple Gigabyte SATA ports with the Gigabyte RAID driver.
I've moved to the orange Intel SATA ports and the Intel RAID driver and all seems ok so far...
Thanks for all your advice. I'll probably be back for more questions soon
Alan
12V combined is 40A or 480W. Should be OK. Reset the CMOS to default timing and reseat the RAM. Memtest86 is a good program to test each stick one at a time.
Ok... I must be missing something. How did you come to the conclusion that his 12V rail is drawing 40A ?
Also, it's a pretty well established fact that most power-supplies under-perform. It's generally a bad idea to run a power suppy - even a brand-name one - at full throttle all the time. My personal rule of thumb is to buy top-shelf psu's that are rated at least 25% over the max the system will ever use.
