Advanced Appearance
How to Change the Advanced Appearance Settings in Vista
This will show you how to change the Advanced Appearance settings that affect the size, color, and text for all windows in Vista.
1. Right click on a empty area of your desktop and click on Personalize. (See screenshot below)​
2. Click on Window Color and Appearace. (See screenshot below)​
3. Click Open classic appearance properties for more color options. (See screenshot below)​
NOTE: If the color scheme Windows Aero (All Vista editions except Home Basic) or Windows Vista Standard (Only Vista Home Basic) is not running, then you will not see this screen. Instead you will see the screen below step 4 instead. To change the clor scheme, see: How to Change the Color Scheme in Vista
A) Click on a color you want to use for the windows, Start menu, and Taskbar.​
B) Adjust the Color intensity by sliding the bar to the left to decrease the intensity and to the right to increase the intensity.​
NOTE: If the Color intensity is set to far to the right, then the window borders and taskbar may be to dark to be transparent if enabled.
4. Click on the Advanced button. (See screenshot below)​
NOTE: The Windows Aero color scheme is not available for the Vista Home Basic version. The Vista Home Basic edition will have the Windows Vista Standard color scheme instead.
5. You will now see the Advanced Appearance settings window.​
6. To Change a Window Item Setting : (See screenshots above)​
A) To Select a Item - Click on the Item drop down menu and select a window item you want to change.​
NOTE: You can also click on the different displayed windows at the top of the Advanced Appearance window to select a Item to.
B) To Change the Item Size - Change the Size number to what you want.​
C) To Change the Item Color - Click on the Color 1 and Color 2 drop down menu and select a color.​
NOTE: The Color 1 and Color 2 refer to items like the title bar and how it fades from Color 1 to Color 2 across the bar. However, the color change will only work in the Windows Classic theme. See: How to Change the Color Scheme in Vista
7. To Change the Font Settings for the Selected Item - (See screenshots below step 5)​
NOTE: The font settings that are grayed out are not available with the selected color scheme. See: How to Change the Color Scheme in Vista and How to Change the Default Vista Fonts
A) To Change the Item Font - Click on the Font drop down menu and select a font. (See screenshot below)​
B) To Change the Item Font Size - Click on the Size drop down menu and select a number for the size. The higher the number, the larger the size.​
C) To Change the Item Font Color - Click on the Color drop down menu and select a color.​
D) To Have the Item Font in Bold - Click the B button to highlight it. If it is not highlighted, then the font will not be in bold.​
E) To Have the Item Font in Italic - Click on the I button to highlight it. If it is not highlighted, then the font will not be in italic.​
8. Repeat steps 6 and 7 until you change all the Items you wanted.​
9. Click OK when done. (See screenshot below step 5)​
10. Click OK to apply. (See screenshot below step 4)​
11. Close the Personalization window. (See screenshot below step 3B)​
Thanks so much for getting back to me.
It's been shut down four times today (every time I tried a restore) but I did restart now and it was still the same.
I've reset Chrome to default and am seeing the same display.
I don't think I've updated a video player recently. I use VLC for pretty much everything (Version 2.1.5) Is it worth uninstalling that?
I tried Opera and the font looks fine in Opera. Perhaps reinstalling my browsers will help?
If you completely reset the browsers, then I'm not sure that reinstalling them may help but wouldn't hurt to try.
Please let us know how it went. :)
Unfortunately reinstalling Firefox didn't help. However I was able to get a fix on the Mozilla forum. Apparently microsoft update kb3013455 can cause font rendering issues on vista and when I undid that update it fixed my problem.
Thanks again for your help.
Great news. Thank you for posting back with your results. :)
