thepizzaman
Banned
good choice :DOK i choose and i bought SAPPHIRE RADEON HD4890 OC 1GB GDDR5
Now i believe my pc is ready.
(Read my System specs)
no they don't actually the 4890 being a much newer card has a much higher bandwidthActually thats wrong. RAM on a graphics card gives it more space to buffer game data so it takes stress of your normal RAM trust me 2GB always gives better performance. also simply by overclocking the 4870 just a little bit you can get the same performance.
no more ram wont give better performance in this case , 1GB is fine , yes for high resolutions , lots of AA and AF and especially if hes running vsync with triple buffering he will need alot of ram but 1GB is enough , the 1gb card has a faster core and more memory bandwidth , it will be a faster card altogether (in this instance obviously im talking specifically about these two cards i dont want to get into an argument about GPU ram usage i do take get the point your trying to get across :D )
they should have the same memory bandwidth.
if you are playing gta4 you will need the extra ram. takes almost 2 to max out the video settings. but i would look at benchmarks for games you want to play (or max out) because you may not need top of the line. used to have a 3870 which ran crysis quite well (not maxed obviously).
either way you go, wait til the new cards come out as the 4xxx series will drastically drop in price.
- Acer, Aspire M1201\Custom Build
- AMD Athlon X2 5000+ @ 2.6Ghz
- Acer Micro-ATX Motherboard
- 2x2gb Patriot Viper DDR2 PC6400 @ 800mhz Dual Channel SLI Edition (4-4-4-12)
- ATI HD3870 with 512mb GDDR4
- Realtek HD 7.1 Onboard Sound
- 22" Acer X223 Widescreen
- 1680 X 1050
- 320gb Western Digital SATA II (Ubuntu 9.10) 500gb Seagate SATA II 1tb Seagate SATA II (Vista Home Premium)
- PSU
- ULTRA X3 600 Watt Modular
- Case
- NZXT Tempest (The Airflow King) 2x 140mm Fans, 4x 120mm Fans
- Cooling
- 1x 135mm In PSU, 1x 70mm On CPU, And 1x 120mm On GPU
- Microsoft Sidewinder X5
- Microsoft Sidewinder X6
- 6 Mbs Down 1 Mbs Up
- Other Info
- AVerMedia 1500MCE TV Tuner Logitech X540 5.1 Surround Sound
