32-Bit or 64-Bit
32-Bit or 64- Bit
  • 32-Bit
    Votes: 2 18.2%
  • 64-Bit
    Votes: 9 81.8%
  • Total voters
    11
Ok thre Reason people think that XP ais better is because Vista had Problems at the Start when it first came out Now after SP2 it is Smoother and BSOD's appear less frequently
    Intel Core i5 2400 @ 3.10GHz
    Foxconn H67MP-S/-V/H67MP
    8.0GB DDR3 @ 665MHz (2GBx4)
    AMD HD Radeon 6870
    SMB1930NW (1440x900@60Hz)
    Novatech Night
    Dell HID-compliant mouse
Actually, Vista had no issues.... the Hardware just had no support :)
Also Vista was pushed out too hard as an update to XP, but the hardware wasn't up to the task of what they claimed it could do.
I think on 2 machines, I've had 1 BSOD, not due to oc'ing, in 2 years, and my desktop is on 24/7 and running mnultiple F@h clients.
    Dual L5639 // i7 950 @ 4.0Ghz
    gtx 560 ti // gtx 260-216
    Dual 22" // Headless
I have no problems with Vista. In its life, 4 BSoDs, all a known cause, all definitely NOT Vista's fault (GMER) and when it first came out, it was a little sluggish for me, but that turned out to only be a dying hard disk. I still use it, have no problems, and my ageing peripherals happen to not work on 7 Beta. I know you are going to say it was in Beta then, but I still see no reason to upgrade from the very good Vista.
    Dell XPS 420
    Stock Dell 0TP406
    4 gb (DDR2 800) 400MHz
    1600 x 1200 and 1280 x 1204
    Stock PSU - 375W
    Dell XPS 420
    Stock Fan
    Dell Bluetooth
    120 kb/s
64bit is better for a lot more reasons than have been mentioned.
However, you need the proper hardware to use it properley. This is where alot of people use to fall over.
Now that most hardware is designed to work with 64 bit os times are getting better.
Most of the early problems to do with driver support was not vistas fault but the manufacturers of the device.
If you put a new audio system in your car and it did not work would you blame the car maker?
64bit os can also handle larger numbers in maths before it has to break them down.
They can handle larger programs for the simple reason they have more memory addresses.
This is more noticable on specialised programs and, the more the computer world progresses the less of a difference it will make.
Look at it this way a 4 bit os can handle 4 bits
this is 1111 in binary which is 15 in denary
now say there was a 5 bit os this can handle an extra digit that is worth 16 in dinary making maths slightly faster.
The more bits you get the larger the number the os can handle, however the number that a 32bit os can handle is very large. Unless you are using specific programs you will not notice much of a difference between them.
This is just my opinion, feel free to add to anything I have said.
    I5 3570K
    Gigabyte Z77-DS3H
    Gigabyte Geforce GTX 660 TI
    creative x-fi
    Both 1680 x 1050
    Technika TKOPTM2
    Logik
That is a Very Good point Roy69, Just one question why is a 32-Bit computer x84 and a 64-Bit x64?
Many thanks,
Josh
    AMD HD Radeon 6870
    Novatech Night
Many thanks,
Josh
intel's architecture on processors was innovative in the 90s, they released an architecture called 8086 which brought operating systems into 32bit revolution, its reffered to as 86-32, then x64 came along and was reffered to as 86-64, its just the original intel architecture that branded it the name x86.
Dave
    Intel Q6600 @ 2.8GHz
    Evga NF78-CK-132-A 3-Way SLI
    EVGA 560 GTX SC FTW 1GB
    Antec 900 Gaming Case
    Logitech generic keyboard
    16Mb Sky bb
I have seen a little about x84, however the proper name as Mr Needs has said is x86.
There was also the 386 and 486 processor.
The main diference is x86 can handle 16bit apps where as x64 has a major problem with them.
    I5 3570K
    Gigabyte Z77-DS3H
    creative x-fi
    Both 1680 x 1050
    Technika TKOPTM2
    Logik
The reason why 32-bit is sometimes referred to as x86 comes from the x86 series of Intel processors - the 286, 386, 486, 586 (pentium), etc. The two terms became synonymous, and people use them interchangeably. There isn't an equivalent for 64-bit, so this became known as x64 just as a shorthand way of writing it. True, 32-bit could also be written as x32, but the x86 representation is well established and used. Even MS use the x86 suffix to distinguish between 32-bit and 64-bit folders, such as Program Files (x86) and Program Files.
    Dwarf Dwf/11/2012 r09/2013
    ASRock Z77 Extreme4-M
    ViewSonic VA1912w Widescreen
    Gigabyte IF233
