3 BSOD's today
Once again, memory issue. I would think you have enough RAM, but you could put in more....
Run chkdsk to look for any corrupted sectors. This error is caused by not enough memory, or (more likely) a corrupted SCSI or IDE driver. Run updates, and chkdsk.
~Lordbob
    ASUS P5QC
    2x2GB
    NVidia GeForce 9500GT 1Gb
    Mobo
    Samsung SyncMaster 206bw
    Razer Lachesis
    Razer Tarantula
    not fast enough
Also, it could be a bad printer driver.
1. Go to the Control Panel and click Printers
2. Right-click on the white space and click "Run as administrator > Server Properties"
3. Click on the "Drivers" tab, click on the offending printer and click on the "Remove" button.
When prompted, click "Remove driver and driver package."
Answer "Yes" when prompted to delete the driver.
4. You will then see a dialog indicating that driver package information has been collected. Click on the "Delete" button.
5. Back in the printer list, delete the offending printer by clicking on it and pressing the Delete key on your keyboard.
For really stubborn printers that refuse to delete, note the files the printer driver uses and delete them while in safe mode. To do so, on the "Drivers" tab (see above), click the printer and click properties. Sort the "File" column alphabetically by clicking on the heading. Write down the files involved and also write down the "driver path" above the "File" column. Delete these files in safe mode, then repeat the removal procedure above.
~Lordbob
    ASUS P5QC
    2x2GB
    Mobo
    Razer Lachesis
    Razer Tarantula
    not fast enough
~Lordbob
Yeah I have a feeling it is this because I googled the error codes and they all pointed to printer driver problems. Thanks.
    Intel Core 2 Extreme QX6700 Kentsfield @ 3.2 Ghz
    Asus Striker Extreme
    4GB Corsair Dominator DDR2 800
    BFG Geforce 9800 GTX+ OC 1GB
    Creative X-Fi Fatal1ty Professional
    22" Samsung 226BW
    1680 x 1050
    1x WD 300GB SATA 1x WD 500GB E-SATA 2x WD 150GB IDE
    Antec True Power Quattro 1000W
    XG Quantum
    Ultra ChillTec CPU Cooler
    Logitech MX518
    Logitech G15
    Optimum Boost
No problem. Post for help if you need it.
~Lordbob
    ASUS P5QC
    2x2GB
    Mobo
    Razer Lachesis
    Razer Tarantula
    not fast enough
