Solved 0xao internal power error bsod on shutdown.
k when I enter "verifier.exe" I get a 'no defices match the name spceified' error. Should I turn off UAC? This should work in Vista right?
I just updated my Nvidia driver as well as the intel chipset & SATA drivers today. All per the Acer website, but still getting the 0xA0 on shut down.
    Acer Aspire 5720
Are you entering verifier.exe into the start menu? It should work in Vista, yes. It has not changed since XP at least (as that's the latest OS I've tested it with).
Be sure to get the latest updates from the Intel site rather than the Acer page, as the drivers found on Intel.com will be more up-to-date.
    Jonathan King
    AMD Athlon Dual Core Processor 4850e overclocked @ 2.92 GHz
    ASRock A780 FullDisplayPort
    6.0GB Dual-Channel DDR2 290MHz Crucial Technology
    ATI 3200 (onboard), nVidia 7200 GS (PCIe)
    17" Cybervison ds69T, 17" Starlogic
    1024x768
    WD 320GB SATA, Hitachi 1TB SATA
    Antec ea-430d 430W
    Antec 300
    stock cpu, 120mm rear, 140mm top
    Microsoft Wired Desktop 500 (USB)
    Microsoft Wired Desktop 500 (PS/2)
    9.32 Mb/s download; 0.36 Mb/s upload
    Other OS's: Windows 7 Professional x64, Windows Professional x86, Ubuntu x64
Yes. START then type in the 'start search' box at the bottom - wit the little magnifying glass to the far right - correct?
Should I try the cmd. prompt instead?
Will do for the intel updates. Actually found a newer NVidia driver on their site as well.
    Acer Aspire 5720
That should be right for the verifier procedure. You might try doing it from the command prompt, and also make sure you have Administrator privileges. Right-click>Run as Admin.
If that doesn't work, then I'm afraid I don't know what to tell you. We can try to go on without it I guess.
    Jonathan King
    1024x768
    Antec ea-430d 430W
    Antec 300
Ok, So a lot happened yesterday. I managed to get verifier.exe to run (after getting an expansion drive and freeing up 20 gigs from the laptop). I configured it as instructed and rebooted (with the 0xA0 bsod on shut down). then when it restarted I immeadiately got a new BSOD (0xC9) so I couldn't boot into windows normally. restarted (0xA0 bsod on shutdown again) and booted into safe mode. From there I attempted to turn off verifier.exe, but got the 'no devices match the name spceified' error again and was stuck.
The only other option I saw was to restart using the 'use last known good configuration option'. This got me into normal mode, but with restricted access, as I got the enter product key for validation nonesense and when I did the software indicated theat the key was already in use - so windows started up with the 'this version of windows is not genuine' txt in the bottom right corner.
After a little hunting around I managed to get that straightened out (I HOPE)
So I'm guessing I should run jcgriff again and post the results for you?
    Acer Aspire 5720
Please. :)
    Jonathan King
    1024x768
    Antec ea-430d 430W
    Antec 300
Here you go. Thanks for all the trouble you are going to. to help me out here. I'm wondering, though, If it ends up that I have to reinstall windows, is there any way to find out if the product key I have is, in fact, defunct? Would like to know that before I wipe the system.
    Acer Aspire 5720
For some reason, the dumps are now mentioning iastor.sys, the Intel storage driver. You say you installed updated chipset drivers? I'm wondering if there might be some relation there.
Try using the Intel Update tool to check for updates: Intel® Driver Update Utility
Code:
iaStor.sys        Wed  Apr 25 14:27:47 2007 (462F9DA3)
iaStor.sys        Thu Jul 12 18:59:22 2007 (4696B24A)
Also, run a few malware scans, just for the heck of it I guess. I'm not sure why the Microsoft anti-malware driver (used by MSE and Defender) is being mentioned a lot, it's possible malware is related.
Run a Full scan with Microsoft Security Essentials, and also a Full scan with Malwarebytes: Malwarebytes Anti-Malware - Reviews and free Malwarebytes Anti-Malware downloads at CNET Download.com
Also run: Free ESET Online Antivirus Scanner
...Summary of the dumps:
Code:
[font=lucida console]
Built by: 6002.18484.x86fre.vistasp2_gdr.110617-0336
Debug session time: Fri Sep  2 13:42:31.482 2011 (UTC - 4:00)
System Uptime: 0 days 2:39:45.926
*** WARNING: Unable to verify timestamp for iaStor.sys
*** ERROR: Module load completed but symbols could not be loaded for iaStor.sys
*** WARNING: Unable to verify timestamp for MpFilter.sys
*** ERROR: Module load completed but symbols could not be loaded for MpFilter.sys
Probably caused by : iaStor.sys ( iaStor+3d464 )
DEFAULT_BUCKET_ID:  VISTA_DRIVER_FAULT
BUGCHECK_STR:  0x8E
PROCESS_NAME:  WmiPrvSE.exe
FAILURE_BUCKET_ID:  0x8E_iaStor+3d464
BiosReleaseDate = 11/10/2008
SystemProductName = Aspire 5720
Debug session time: Fri Sep  2 11:00:06.550 2011 (UTC - 4:00)
System Uptime: 0 days 12:45:14.836
BUGCHECK_STR:  0x8E
Debug session time: Thu Sep  1 21:29:24.692 2011 (UTC - 4:00)
System Uptime: 0 days 0:27:52.594
DEFAULT_BUCKET_ID:  COMMON_SYSTEM_FAULT
BUGCHECK_STR:  0x8E
Debug session time: Thu Sep  1 20:51:47.013 2011 (UTC - 4:00)
System Uptime: 0 days 0:17:08.655
Probably caused by : ntkrpamp.exe ( nt!PopAllocateIrp+a0 )
BUGCHECK_STR:  0xA0
PROCESS_NAME:  wininit.exe
FAILURE_BUCKET_ID:  0xA0_nt!PopAllocateIrp+a0
Debug session time: Thu Sep  1 20:34:02.136 2011 (UTC - 4:00)
System Uptime: 0 days 0:20:05.762
*** ERROR: Module load completed but symbols could not be loaded for mssmbios.sys
BUGCHECK_STR:  0xA0
Debug session time: Thu Sep  1 20:09:38.827 2011 (UTC - 4:00)
System Uptime: 0 days 1:04:36.850
BUGCHECK_STR:  0xA0
Debug session time: Thu Sep  1 14:39:52.475 2011 (UTC - 4:00)
System Uptime: 0 days 0:10:10.229
BUGCHECK_STR:  0x8E
Debug session time: Thu Sep  1 14:26:10.802 2011 (UTC - 4:00)
System Uptime: 0 days 0:05:39.676
BUGCHECK_STR:  0x8E
Debug session time: Thu Sep  1 14:19:52.346 2011 (UTC - 4:00)
System Uptime: 0 days 0:10:32.267
BUGCHECK_STR:  0x8E
Debug session time: Thu Sep  1 14:03:34.524 2011 (UTC - 4:00)
System Uptime: 0 days 0:10:35.368
BUGCHECK_STR:  0x8E
Debug session time: Thu Sep  1 13:51:07.950 2011 (UTC - 4:00)
System Uptime: 0 days 0:47:33.454
BUGCHECK_STR:  0xA0
Debug session time: Thu Sep  1 13:02:27.462 2011 (UTC - 4:00)
System Uptime: 0 days 0:03:35.367
BUGCHECK_STR:  0x8E
Debug session time: Thu Sep  1 12:58:11.649 2011 (UTC - 4:00)
System Uptime: 0 days 0:03:28.537
BUGCHECK_STR:  0x8E
Debug session time: Thu Sep  1 12:54:07.206 2011 (UTC - 4:00)
System Uptime: 0 days 0:04:20.076
BUGCHECK_STR:  0x8E
Debug session time: Thu Sep  1 12:49:08.725 2011 (UTC - 4:00)
System Uptime: 0 days 0:10:32.623
BUGCHECK_STR:  0x8E
Debug session time: Thu Sep  1 12:33:21.639 2011 (UTC - 4:00)
System Uptime: 0 days 0:03:30.405
BUGCHECK_STR:  0x8E
Debug session time: Thu Sep  1 12:27:50.266 2011 (UTC - 4:00)
System Uptime: 0 days 0:48:57.896
BUGCHECK_STR:  0xA0
Debug session time: Thu Sep  1 11:38:11.694 2011 (UTC - 4:00)
System Uptime: 0 days 0:03:26.583
BUGCHECK_STR:  0x8E
Debug session time: Thu Sep  1 11:33:59.782 2011 (UTC - 4:00)
System Uptime: 0 days 0:10:22.548
BUGCHECK_STR:  0x8E
Debug session time: Thu Sep  1 11:21:47.899 2011 (UTC - 4:00)
System Uptime: 0 days 19:47:58.873
BUGCHECK_STR:  0x8E
Debug session time: Wed Aug 31 15:30:37.066 2011 (UTC - 4:00)
System Uptime: 0 days 0:43:50.672
Probably caused by : ntkrpamp.exe ( nt!ExQueueWorkItem+21 )
BUGCHECK_STR:  0xE4
PROCESS_NAME:  System
FAILURE_BUCKET_ID:  0xE4_nt!ExQueueWorkItem+21
Debug session time: Wed Aug 31 14:45:29.356 2011 (UTC - 4:00)
System Uptime: 0 days 1:05:59.576
BUGCHECK_STR:  0xA0
Debug session time: Wed Aug 31 13:37:12.331 2011 (UTC - 4:00)
System Uptime: 0 days 0:57:16.406
BUGCHECK_STR:  0xA0
Debug session time: Wed Aug 31 12:39:12.162 2011 (UTC - 4:00)
System Uptime: 0 days 1:15:29.113
BUGCHECK_STR:  0xA0
Debug session time: Wed Aug 31 11:23:04.982 2011 (UTC - 4:00)
System Uptime: 0 days 0:05:36.607
BUGCHECK_STR:  0xA0
Debug session time: Wed Aug 31 11:08:16.482 2011 (UTC - 4:00)
System Uptime: 0 days 0:08:13.107
BUGCHECK_STR:  0xA0
Debug session time: Wed Aug 31 10:10:54.879 2011 (UTC - 4:00)
System Uptime: 0 days 1:54:34.162
BUGCHECK_STR:  0xA0
Debug session time: Wed Aug 31 08:15:45.439 2011 (UTC - 4:00)
System Uptime: 0 days 0:05:24.064
BUGCHECK_STR:  0xA0
Debug session time: Tue Aug 30 21:17:39.540 2011 (UTC - 4:00)
System Uptime: 1 days 1:05:03.222
BUGCHECK_STR:  0xA0
Debug session time: Mon Aug 29 19:43:09.057 2011 (UTC - 4:00)
System Uptime: 0 days 0:09:44.873
Probably caused by : iaStor.sys ( iaStor+9970 )
BUGCHECK_STR:  0x8E
FAILURE_BUCKET_ID:  0x8E_iaStor+9970
Debug session time: Mon Aug 29 19:31:35.077 2011 (UTC - 4:00)
System Uptime: 0 days 3:33:15.289
BUGCHECK_STR:  0xA0
Debug session time: Mon Aug 29 12:02:30.293 2011 (UTC - 4:00)
System Uptime: 0 days 1:51:26.549
*** ERROR: Symbol file could not be found.  Defaulted to export symbols for ataport.SYS -
Probably caused by : ataport.SYS ( ataport!AtaPortGetScatterGatherList+a75 )
BUGCHECK_STR:  0x8E
FAILURE_BUCKET_ID:  0x8E_ataport!AtaPortGetScatterGatherList+a75
Debug session time: Mon Aug 29 09:48:08.866 2011 (UTC - 4:00)
System Uptime: 0 days 0:12:20.808
BUGCHECK_STR:  0x8E
Debug session time: Mon Aug 29 09:34:53.147 2011 (UTC - 4:00)
System Uptime: 0 days 0:11:17.914
BUGCHECK_STR:  0x8E
Debug session time: Mon Aug 29 09:22:43.721 2011 (UTC - 4:00)
System Uptime: 0 days 0:11:11.627
BUGCHECK_STR:  0x8E
Debug session time: Mon Aug 29 08:49:23.271 2011 (UTC - 4:00)
System Uptime: 0 days 0:11:51.897
BUGCHECK_STR:  0xA0
Debug session time: Sun Aug 28 18:10:13.481 2011 (UTC - 4:00)
System Uptime: 0 days 0:18:27.493
BUGCHECK_STR:  0x8E
Debug session time: Sun Aug 28 17:43:10.795 2011 (UTC - 4:00)
System Uptime: 0 days 0:06:34.420
BUGCHECK_STR:  0xA0
Debug session time: Thu Aug 25 16:26:57.173 2011 (UTC - 4:00)
System Uptime: 0 days 7:39:19.141
BUGCHECK_STR:  0xE4
[/font]
    Jonathan King
    1024x768
    Antec ea-430d 430W
    Antec 300
ok these are the results from the Intel® Driver Update Utility
Graphics Driver
Product Detected NVIDIA GeForce 8400M GS Current Driver Installed 8.17.12.8026 This device is unknown or unsupported. Please contact the manufacturer for possible updates. More information>>
Intel Chipset Software Installation Utility (Chipset INF)
Product Detected Intel® 6, 5, 4, 3, 900 Series Chipsets Current Version Installed 9.1.1.1015 This version is valid.
Audio Driver for Intel Desktop Board
Product Detected High Definition Audio Device Current Driver Installed 6.0.6002.18005 This device is unknown or unsupported. Please contact the manufacturer for possible updates. More information>>
Wireless Networking (WiFi)
Product Detected Intel® PRO/Wireless 3945ABG Network Connection Current Driver Installed 13.4.0.139 Your driver is current.
Wired Networking
Product Detected
Current Driver Installed 10.10.0.1 This device is unknown or unsupported. Please contact the manufacturer for possible updates. More information>>
working on the rest of it.
    Acer Aspire 5720
iaStor.sys Wed Apr 25 14:27:47 2007 (462F9DA3) iaStor.sys Thu Jul 12 18:59:22 2007 (4696B24A)
Pretty sure those were from the morning of Sept 1st, when the seagate expansion drive I'd gotten was being installed. there was some software it wanted to insall that I ended up opting out of cus it caused a bsod. Pretty sure it was an 0x8e iastor bsod. that make any sense?
doing Malwarebites full scan now. Security Essentials is on with realtime protection and has not been reporting anything. Can't see it in my sys. tray though, how do I get it to scan?
    Acer Aspire 5720
Hey, I just noticed in the last summary of the dumps there was no mention of the
Bug Check 0xC9: DRIVER_VERIFIER_IOMANAGER_VIOLATION
that I saw when I had driver verifier activated.
should I try to run it again?
    Acer Aspire 5720
To do a scan with MSE, find the program in start menu or tray (might have to Expand the tray), and the option should be there in the first tab.
Try running driver verifier again. You might want to create a restore point first to make restoring easy. See here: System Restore Point - Create - Windows 7 Forums
When it crashes, check to see if there is a minidump file in C:\Windows\Minidump. Keep Driver Verifier running until you get a crash that leaves a dump (within a reasonable time period - a few days?).
A repair install is also an excellent option at this point; I believe something is messed up with the OS, possibly on top of another problem. See here: http://www.sevenforums.com/tutorials/3413-repair-install.html
    Jonathan King
    1024x768
    Antec ea-430d 430W
    Antec 300
Unfortunately I don't have the right disc to do a repair install. (Mine is OEM i'm pretty sure)
If Driver Verifier causes the system to crash before it boots into windows, is it any use? will there (or should there) be a dump file created?
    Acer Aspire 5720
I'm not exactly sure the point at which Windows can create a crash dump. You'd have to just try it and see; if no dump is created, keep it running and hope it does next time!
If a clean install isn't too much of a problem, that might be your next best bet.
    Jonathan King
    1024x768
    Antec ea-430d 430W
    Antec 300
I'm thinking a clean install is the way to go here too. I've already started backing files up on my expansion drive. it just sucks that I'm gonna loose Nero, and Acrobat (no disks to reinstall them).
    Acer Aspire 5720
If you need recommendations to replace Nero, I could help you out, and Acrobat Reader is a free download. Can't create/edit PDFs with Reader though.
    Jonathan King
    1024x768
    Antec ea-430d 430W
    Antec 300
    Jonathan King
    1024x768
    Antec ea-430d 430W
    Antec 300
Happy days! Reformatted & reinstalled a couple of days ago and everything is running smoothly. Thanks for all your help with this.
    Acer Aspire 5720
