(0x0000003b) and other errors
    Dell Inspiron DeskTop 546/546s
    ACPI x64-based PC
    2.00 GB
    AMD Radeon HD 3200 Graphics
    VIA HD Audio Codec Driver v6.71.32.090107
    Dell In1910N(analog) on ATI HD 3200 Graphic
    1024 by 768 pixels
    283 GB
    Built-in Fan
    HID-compliant mouse
    HID Keyboard Device
    6 mbps
    DSL provided by Frontier
richc46
here is what the crystal info pulled up
NoelDP is there a way to run the DFT without a disk, i dont own blank disks and my computer does not have a floppy drive.
    ACPI x64-based PC
    2.00 GB
    1024 by 768 pixels
    283 GB
    Built-in Fan
    HID-compliant mouse
    HID Keyboard Device
    6 mbps
If that current pending sector count was the only Yellow warning, Crystal indicates that the problem is not the hard drive.
05 Reallocated sectors count is also yellow, if any help.
If it is not the hard drive, then we were heading in the wrong direction?
    ACPI x64-based PC
    2.00 GB
    1024 by 768 pixels
    283 GB
    Built-in Fan
    HID-compliant mouse
    HID Keyboard Device
    6 mbps
Try WinDFT (link on the page) - it may work with your drive
Run another CHKDSK /R if it doesn't, and post the results - in the Event Viewer > Windows Logs > Application as a Wininit event
    Acer Aspire 8930G
It didnt pull up my hard drive, ill try posting the CHKDSK in the event viewer.
you said to put it as a "
Wininit event", how do i do that?
in my event viewer, there are more than several errors. Is there a way for me to send that to you?
    ACPI x64-based PC
    2.00 GB
    1024 by 768 pixels
    283 GB
    Built-in Fan
    HID-compliant mouse
    HID Keyboard Device
    6 mbps
IN the Event Viewer main pane (center top), look in the Source column. Wininit will appear there.
You can also use the Filter - this should find it very quickly. click on Filter current log, and click on the event Sources down-arrow - put a tick in the Wininit box, and click OK
If you're desperate, export the whole log and zip it up, thenattach it to a reply, and I'll take a look.
    Acer Aspire 8930G
Wininit file seems not to exist on my computer, I've searched for it.
Is it a problem that the file does not exist?
I'm also starting to get error message that: \device\harddisk0\DR0, has a bad block
Whatever that is about.
    ACPI x64-based PC
    2.00 GB
    1024 by 768 pixels
    283 GB
    Built-in Fan
    HID-compliant mouse
    HID Keyboard Device
    6 mbps
    ACPI x64-based PC
    2.00 GB
    1024 by 768 pixels
    283 GB
    Built-in Fan
    HID-compliant mouse
    HID Keyboard Device
    6 mbps
Look in the event viewer for the file or something else?
Plenty of errors in the event viewer
    ACPI x64-based PC
    2.00 GB
    1024 by 768 pixels
    283 GB
    Built-in Fan
    HID-compliant mouse
    HID Keyboard Device
    6 mbps
    ACPI x64-based PC
    2.00 GB
    1024 by 768 pixels
    283 GB
    Built-in Fan
    HID-compliant mouse
    HID Keyboard Device
    6 mbps
    ACPI x64-based PC
    2.00 GB
    1024 by 768 pixels
    283 GB
    Built-in Fan
    HID-compliant mouse
    HID Keyboard Device
    6 mbps
The log doesn't really tell us much that we didn't already know :(
this may help...
Open Windows Explorer (Computer)
Navigate to the C:\Windows folder
Find the System32 sub-folder and right-click on it
select Properties
Clear the 'blob' from the 'Read-only (Only applies to files in folder)' box by clicking on it until it's plain white.Click on Apply.Make sure that the radio button for 'Apply changes to this folder, subfolders and files' is set, and click OK.
Accept the Administrator prompt. After a couple of seconds, you'll be told there is an error - click on the 'Ignore all' button.
Wait for it to finish - it could take a couple of minutes.
OK out, and exit Windows Explorer.
Reboot twice
Then test the results
    Acer Aspire 8930G
Test still showed problems, my computer still crashes.
Is there anything else to do?
    ACPI x64-based PC
    2.00 GB
    1024 by 768 pixels
    283 GB
    Built-in Fan
    HID-compliant mouse
    HID Keyboard Device
    6 mbps
