System Restore Problem
youngharry
Hi
I have been having a problem with 'System Restore' I have tried to restore my sytstem
to different restore points but always end up getting the same message:
"System Restore did not complete successfully. Your computer's system files
and settings were not changed.An unspecified error occurred during System Restore.You might try System Restore again and choose a different restore point."
My OS is Vista business, 32bit, Service Pack 1. Installed on a Sony Vaio NR21M laptop.
200gb H/D & 2.0.gb ram.
I was wondering if anyone else has had this problem & could offer some advice.
Many thanks
Harry
Did you get any error numbers? Do you have any Norton/Symantec sofware installed try this link
http://bertk.mvps.org/html/symantecdoc1.html
If you receive an error while restoring, then use it from safe mode and it should work fine. To get into Safe mode, you can reboot and use the F8 key right before Windows starts up.
Or maybe this will help you
For the 32bit and 64bit question, you can refer to the following thread:
http://forums.microsoft.com/TechNet/ShowPost.aspx?PostID=2340069&SiteID=17
Hope some of it will help
    Q6600
    MSI P36 NEO2
    4GB 5-5-5-12
    8800GTS 512Mb Overclocked
    5.1 surround sound
    500Gb Samsung SATAII XP 500GB Samsung SATAII
    1000W CoolerMaster power supply
    CoolerMaster Cosmos 1000 case
    120mm ThermalTake Big Typhoon CPU cooler, 3 x 120mm exhaust
    Wireless Keyboard and mouse 3000
    1TB WD My Book Office edition external drive x 2, Dual layer LG DVD-Rom burner, 15 in 1 card reader Triple boot: XP, Vista Ultimate 64 and Windows 7 Ultimate 64
Hi
Thanks for the reply.
I don't have any Norton installed. The error message did not supply me with a specific error number it said An unspecified error occurred. I am running AVG? I am going to try a few things that I found out on the Bert Kinney 'Microsoft Most Valuable Professional' website System Restore in Windows Vista:
I will report back to the forum if I find a solution to this problem.
Thanks for the suggestions & any further would be welcome.
Harry
hi guys 1st post here ,am having the same problem as youngharry, running vista and xp in dual boot ,have applied reg fix to hide vista from xp ,but whenever i try a system ,i get the same responce as youngharry , any one any ideas thanks
ed:cry:
Hi, edintrouble, and welcome to the forums.
Did you go into Vista and manually make a new restore point, and then see if the new restore point works? XP may have already messed up those SRPs before you got the chance to hide Vista from it....
    The Beast Model V (homebrew)
    Realtek HD Audio (onboard)
    2 * 1920 x 1080
    Logitech MX Master (shared)
    Logitech G15 (gen 2)
    Lenovo ThinkPad E545
    AMD A6-5350M APU
    Lenovo
    Conextant 20671 SmartAudio HD
    Lenovo 15" Matte
    1680 * 1050
    Lenovo
    Lenovo
    Lenovo
    Lenovo
thanks johngalt for the reply and apoliges for the delay in replying to you,
yes i have done as you suggested but still no joy ,any other ideas ,thanks
ed
thanks Sid for advice , worked well in S M ,BUT STILL WONT WORK FROM vista normally ,any ideas on this error message says "an unexpected error occured during system restore "???????,starting to thing of going back to XP !!!
thanks again
eddie
Hi eddie,
It should come from a driver conflict, reason why i asked you to try in safe mode.
Now, unfortunately the infos i have do not allow me to point on a specific driver??
Run a sfc /scannow from an elevated command prompt, does not hurt and could resolve the problem.
Vista is a fantastic OS when you know how important things work, unfortunately, many drivers aren't fully compatible and some progs, even edited by big known companies are not fully compatible with Vista, mainly due to UAC.
Do you have a restore point after the SP1 install? Did you try it with your administrator account instead of your user account?
    16GB DDR667
    SAS RAID
thanks Sid and Michael for your help and time with my problem,Michael ,I had a problem ,with sp1 ,so uninstalled (no internet connection,after a bit o research ,found out Zone alarm needed updating to a new version,) up dated and was about to reinstall sp1 when icame accross the restore issue,.Iam new to vista and only finding my way around and while Sid says "Vista is a fantastic OS " I CANT SAY i am enjoying it at the moment
how do i try the admin account ,you talked of ??
XP looks more enticing as each day passes:(
thanks Ed
Hi Guys
I've been following the threads, I haven't been able to fix problem yet. I agree with edintrouble though, I don't want to have to access 'Safe Mode' every time I want to do a 'System Restore' & really we shouldn't have to.
I am running Zonealarm latest version for Vista & AVG, I read something on another forum (that I can't find now) that Zonealarm could be the problem. I have Vista business & SP1. I will find a way of fixing this problem & when I do will obviously post it up, problem I am having at moment is time - I haven't been able to focus my mind on this problem to sort it. System Restore is quite an important utility for getting out of trouble so we'll get it sorted.
Don't give up on Vista edintrouble I think it is basically sound. I was reluctant to let go of XP-Pro initially, but am generally glad I did.
Regards
Harry
Agree, but are a driver or a AV software problems due to Vista?
Good point Sid...
These two are both compatible with Vista and FREE!
FREE avast! antivirus 4.x Home Edition, anti-spyware & anti-rootkit for Windows
Free Firewall Protection Software Best Firewall Computer Security Free Personal Firewall
Later :shock: Ted
    * BFK Customs *
    Intel C2Q 9550 Yorkfield
    ASUS P5Q Pro
    8GB Dominator 8500C5D
    XFX ATI 1GB 4870 XXX
    Realtek HD 7-1
    1920x1080P & 1920x1200
    Corsair 620HX
    CM Cosmos RC-1000
    Razer Diamondback 3G
    HP Enhansed Multimedia
    18.6Mb/s
    My First Build ;)
harry ,sid john ,michael and bare foot,
thanks again for your thoughts and advice on this issue ,over 7 days spent trying to resolve this issue and still no closer to resolve,,ive been using the pc for over 7 years and this little issue is one of the longest without a fix ,harrry how are yo getting on ? will take advice re not giving up on vista ( dog and bone) sid do you really think its a driver issue, ??
thanks again lads
ed
If you google "sysRestorePoint.exe" you will see a MVP has created a little program that you can run manually or set up a schedule in order to create restore points.
I use it as the only way in Vista to create restore points
I have to ask you this after reading this response...
If you're using System Restore that much, I think it's time we ask ourselves "Why" am I having to restore so many times...and work on that area a bit more.
With that said, System Restore can be a very touchy operation and many things can cause it not to run properly when booted into normal windows, so Safe Mode is often needed in these cases, just like Sydney mentioned when a 3rd party driver can cause it's failure in normal mode, but so can many other things cause this failure.
Secondly, it still can be a bit buggy. We thoroughly tested SysRestore on my other Tech site and wrote a number of papers on it under XP (XP, SP1, SP2). We found that it failed in over 43% of the time and in 11% it caused the system to need reinstallation afterwards...not good numbers IMHO.
I have tried SysRestore in Vista myself and it failed 4 times and worked once. This was during Beta testing Comodo Firewall.
One thing you can check is the CBS Logs, Windows\Logs\CBS.log or CBS.persist.log for more info on the failures. You have to know exactly the time you tried the restore and make sure you check the log's last "modified" date to get the right one. They are Large and may not open in Notepad, or will look like it's frozen but it just takes some time to load.
They are big and you'll need to get the date/time right, or check immediately after you have a failed restore and then go to the bottom and work up till you get to the start of the restore, and then look for Failure messages. These logs log all system processes and may be daunting but be persistent because good info is in there on these failures.
But again, I just have to say that if you're depending on System Restore to the point that it seems you guys are, then there is actually a different problem we should be looking at, and that's your habits on a computer that causes the corruptions needing a restore. Or, is it simply a case of you using restore to fix little things that it shouldn't be used for? This is another common mistake by newer users they simply don't know any better or how to research and fix little things and end up using SysRestore more than it should be.
One more thing...NEVER restore to a point older than 1 week old. Too many other system changes have taken place in that time and that also makes SysRestore buggy and prone to failure, sometimes catastrophically so (see 11% above)...
    Personal Build
    Intel E6750 Core 2 Duo
    Asus Commando MoBo (P965/ICH8R)
    4G's Crucial Ballistix Tracer DDR2 PC26400 RAM
    BFG 8800GTS OC2 320MB
    Creative Sound Blaster X-FI Platinum FATAL1TY (next)
    2 x 22" w2207 LCD Monitors
    1- 1680 x 1050, 1 - 1920 x 1080
    3 x 500G SATA II WD Caviar HDD's
    EnerMax NoiseTaker II 600W
    NZXT Lexa Classic (modified, dual doored & windowed)
    Zalman 9700 CPU cooler, 4-120mm fans, 1-90mm
    Logitech Optical Trackman trackball
    NZXT Lexa Classic Case, Zalman 9700 CPU Cooler, 2 DVD Burners c/w LightScribe (Sony, TSST), Enermax NoiseTaker II 600W PSU with Custom Chrome cable sleeving, Hauppauge HDTV TV Tuner Card, 5.1 Logitech Z5500 speakers, 15 in 1 Multi-card reader
