Vista ISO - Download and Create Installation DVD or USB
How to Download a Vista ISO and Create an Installation DVD or USB
Downloads are available for the 32 (X86) and 64 bit (X64) versions of Vista Ultimate only, in English, French and German, but if, during the install, you do not enter the product key when initially prompted for it then you will be asked to select the version of Vista you want to install. It can be any of these four:
Windows Vista Home Basic
Windows Vista Home Premium
Windows Vista Business
Windows Vista Ultimate
You must have a valid installation key, which should be on the COA sticker on the computer, to activate the installation once it completes.
STEP ONE
To Download the Vista Setup Files
The Vista downloads listed below seem to come and go. Right now, 10/12/2014 at 3:39PM EST they are available. I don't know of any other location they are legally available from, sorry.
1. Downloaded the Vista X64 or X86 setup files.​
download
X64 (64 bit):
install.wim​
boot.wim​
X14-63453.exe​
X86 (32 bit):
install.wim​
boot.wim​
X14-63452.exe​
Both X14-63453.exe and X14-63452.exe will be downloaded as MicrosoftInstaller.exe. For consistency, please rename MicrosoftInstaller.exe to X14-63453.exe or X14-63452.exe, depending on which you downloaded.
Wait for all downloads to complete before continuing
2. Double click (or right click and Open) on the downloaded X14-63453.exe or X14-63452.exe. It extracts all the files into a Vista sub-folder.​
3. If they are not already there, copy boot.wim and install.wim into the Vista\sources folder that is created when you doubled clicked on the .exe file in step 2.
4. Download the Windows Bootable Image Creator zip file, WBICreator.zip.​
download
5. Extract the files in WBICreator.zip to a folder.​
STEP TWO
To Create the Vista ISO File
You can download the files on any computer but you must be running on a 64bit (X64) system to create a 64Bit install DVD or flash drive
6. Open the folder and double click (or right click and Open) WBICreator.exe
7. Click Next
8. Select OS Type: Windows Vista (all the way to the bottom)​
9. CD/DVD Label: VistaX64 or VistaX86
10. Setup Location: The Vista folder created when you double clicked on X14-63453.exe or X14-63452.exe.​
11. Output Path: Somewhere with enough free space to hold the .iso file that will be created (X64 = 3,837,112KB, X86 = 3,013,816KB).​
12. Click GO. When done a VistaX64.iso or VistaX86.iso file will be created in the Output Path you chose.​
STEP THREE
To Create Vista Installation DVD or USB Flash Drive with ISO File
13. You can use the generated .iso to create a Vista Install DVD.​
13a. Download and install and run ImgBurn.​
13b. Make sure you deselect anything other than ImgBurn during the install by always taking the Custom choice.​
13c. Click on Write image file to disc
13d. Click the Browse for file button and selecta the ISO file you just created.​
13e. Click Write. A nice little tune will play when the DVD create completes.​
14. You can also create a bootable USB Flash drive (4GB or larger) to install Vista from.​
14a. Download and run Universal USB Installer Easy as 1 2 3
14b. Select Vista from the first drop down list, all the way to the bottom​
14c. Select the VistaX64.iso or VistaX86 .iso file​
14d. Select your USB flash drive​
14e. Click Create​
I created a X86 flash drive and used it to install a clean copy of Vista Home Basic on my HP DV2200 Laptop. Worked great using the key on the COA sticker of the laptop.
Remember to activate after the install has completed.
Note: You may need to download drivers for the computer from the manufacturers web site so I would suggest getting the Network (LAN and Wireless) and video/VGA drivers ahead of time so you can install them as soon as you finish installing Vista.
  • WBICreator.zip
You can test the Vista DVD once you burn it. Download and install Oracle VirtualBox of VMware then use the Vista DVD to setup a VM (Virtual Machine) using the Vista DVD.
Thanks for the suggestion, Ztruker! I saw another post of yours in which you mentioned doing this, but what you were referring to didn't register in my head until now. I've been thinking of installing VMware on my Windows 7 PC (instead of Microsoft's XP Mode software) so that I could run XP as a VM, but it never occurred to me that I could do the same thing with Vista because I don't have any use for Vista on my PC. But doing this as a test procedure would be an ideal way to make sure that my mother won't have any issues with the Vista installation DVD when I send it to her. How much free space should I have on my C drive to do this? I currently have 38 GB free out of 86 GB total, but I could expand my C drive by an additional 10-15 GB if need be. In fact, I was thinking of doing this as well to make sure I have enough breathing room.
    eMachines W3653
    E1200 Celeron 1.6 GHz
    2 GB
20GB should be enough.
    Windows 10 Pro X64
    Lenovo IdeaCenter K450
    Intel(R) Core(TM) i7-4770 CPU @ 3.40GHz, 3401 Mhz, 4 Core(s)
    16GB
    NVIDIA GeForce GTX 750, Intel(R) HD Graphics 4600
    Samsung 27" C27F398 Curved Monitor
    1920 x 1080 (HDMI)
    Samsung SSD 840 EVO 250GB
    Seagate ST2000NM001 2TB
    Seagate ST31500341AS 1.5TB
    500W
    Lenovo USB
    50MB Down, 10MB Up
    Windows 7 Pro X64
    HP xw4400 Workstation
    Intel Pentium D Dual 3.4Ghz
    HP 0A68h
    5GB
    ATI FireGL V3300
    Realtek HD Audio
    Acer KN242HYL 24" (KVMS)
    1920X1080
    Seagate ST3120026As 120GB SATA (boot)
    Toshiba DT01ACA200 2TB SATA
    Logitech via KVMS switch
    Dell USB via KVMS switch
    50 Down, 10 Up
    Apache Web Server since 2001
How do I contact you to obtain the link to your Vista .iso file? I don't see any options to send you a message. Hopefully, you'll see my reply to your post and will send me a message.
Link sent
    Lenovo Thinkpad T400
    LENOVO 64734VM
    Conexant 20561 SmartAudio HD
    15 inch
    1x 180GB Intel 530 series SSD
    1 x 120GB Hitachi 5400rmp
    Medium for New Zealand
    Only ever used a laptop.
    Also use USB Freeview TV Card
    Lenovo Docking Station
    External Speakers
    Other bits a pieces as needed
The MD5 (not MDS) is the check-sum value of the ISO. If you run a program against the ISO that generates check-sum values, including MD5 then you can compare the results. If the same then you know the ISO file is identical to the one on the web site, no corruption.
All you need to do is burn the ISO to a DVD using a program like Imgburn, or better yet, create a flash drive to install from. I use a program called Rufus to create bootable flash drives, but all you really need to do is format the flash drive as FAT32 then copy the contents of the ISO to the flash drive.
Correct all you need do is burn the .iso
The file was separated because people were having problems with the download
    LENOVO 64734VM
    15 inch
    External Speakers
    LENOVO 64734VM
    15 inch
    External Speakers
I think creating a bootable USB is easier than creating a bootable DVD,about downloading Windows 10 iso,many free download sources on Google,about burning Windows iso file,it is better to use Rufus do that,or use this software .
    windows 10
i have question. dose the vista download iso have repair your pc part? i did make windows vista home premium dvd long time ago but when i installed it there no repair this pc icon at lower left of screen.
Yes, it has the Repair your pc functions. It is at the lower left of the "Install Now" screen.
    Vista
    Intel E8400
    ASRock1333-GLAN R2.0
    4gb DDR2 800
    nvidia 9500GT 1gb
    win7/vista
    intel i5-8400
    gigabyte b365m ds3h
    ballistix 2x8gb 3200
The installation media is the same for all of those. The only difference is the license key.
    Vista
    Intel E8400
    4gb DDR2 800
    nvidia 9500GT 1gb
    win7/vista
    intel i5-8400
    gigabyte b365m ds3h
Hello, I had a HP a6700f desktop with an OEM version of Vista, and the motherboard failed. So I ordered a different motherboard (ASRock), new memory, a new case, and a better CPU. I retained the original HDD with the OEM copy of Vista. With everything installed, I tried booting up on the new motherboard, but it would blue-screen. I then changed the HDD from default ACHI to IDE mode, and it booted up. All I had to do was re-enter the product key, and it activated perfectly. Now, my problem is that I can't access HP's recovery options to restore the PC to the original condition. If I create a Vista image using the method above, can I use the Vista x64 OEM product key from my HP a6700f, or am I better off purchasing a new copy of Windows?
Most of the problem could be that you changed a bunch of hardware without uninstalling the drivers. I would boot into safe mode, go to the device manager, and uninstall all the drivers that were for hardware that I no longer had, then reboot and install the updated drivers. I would highly recommend doing a full backup before all of this.
    Windows Vista Ultimate x64
    Hewlett Packard/ HP Pavilion a6250z
    AMD Live! x64
    2 GB
    NVIDIA GeForce 8300 GS
    Creative Sound Blaster X-Fi Xtreme Audio
    HP 2011 Series Wide LCD Monitor
    1600x900 60hz
    Hitachi HDT725025VLA SCSI Disk
    Is not to factory settings; came with a clean install of vista when bought
    Dell Optiplex 7010
    Intel Core I7 3770
    Uses two firewalls (COMODO and Windows Firewall)
Do you realize that he posted in 2015- 7 years ago?
    Vista Home Premium 64 bit SP2
    Cyberpower
    Intel Quad CPU Q6700 2.67 GHZ
    NVIDIA 780i
    MSI GTX 560 TI Twin Frozr
    Sound Blaster SB Audigy
    Viewsonic VG2436
    1920x1080p
    Samsung HD 105SI
    WDC WD20
    Apevia XJupiter
    air
    Logitech MX 3200
    Logitech MX 600
    30 Mbps
Everything you need is in the ISO I gave you.
    Cyberpower
    NVIDIA 780i
    Viewsonic VG2436
    1920x1080p
    Samsung HD 105SI
    WDC WD20
    Apevia XJupiter
    air
    Logitech MX 3200
    Logitech MX 600
    30 Mbps
I thought S1W2 said all versions were in it. It sounds like you were able to burn it to disc? I don't think the .exe you're looking for is the actual Windows setup file that I used and I can't remember the exact file name. Perhaps someone here will help.
    Cyberpower
    NVIDIA 780i
    Viewsonic VG2436
    1920x1080p
    Samsung HD 105SI
    WDC WD20
    Apevia XJupiter
    air
    Logitech MX 3200
    Logitech MX 600
    30 Mbps
STEP ONE
download
X64 (64 bit):
install.wim​
boot.wim​
X14-63453.exe​
X86 (32 bit):
install.wim​
boot.wim​
X14-63452.exe​
download
STEP TWO
7. Click Next
STEP THREE
14e. Click Create​
Note:
this is a really good tutorial! @Ztruker
    Windows 7 Ultimate x64
    HP Elite 8300
    I5-3750
    HP Elite Motherboard
    8GB Ram
    Intel HD Graphics 2500/Nvidia GT 1030 2GB
    Realtek Speakers (Built In)
    Dell Square Monitor (60-75ghz)
    1024x960
    500GB HDD
    HP 240w PSU
    HP Elite Black Computer Case
    HP CPU Fan
    I Live Keyboard (Glow)
    I Live Mouse (Glow)
    2-5Ghz
that iso dont have enterprise edition & MicrosoftInstaller.exe is not included
How do you know? If you have it on a bootable disc, it will install it without any additional files.
    Cyberpower
    NVIDIA 780i
    Viewsonic VG2436
    1920x1080p
    Samsung HD 105SI
    WDC WD20
    Apevia XJupiter
    air
    Logitech MX 3200
    Logitech MX 600
    30 Mbps
