Start Menu - Restore Missing Default Shortcuts
How to Restore Missing Default Start Menu Shortcuts in Vista
This will provide you with separate downloads that include all of the All Programs default shortcuts in the Start menu for each edition of Vista so you can either restore all of the shortcuts or just the ones you need.
A Start Menu shortcuts download for the Vista Enterprise edition is not included in this tutorial. You can use the download for Ultimate in it's place.
EXAMPLE: Start menu All Programs for Vista Home Basic, Home Premium, Business, and Ultimate
NOTE:
To compare and see the features in each edition of Vista, see: Windows Vista Editions Overview and The Vista Editions Comparison Table
STEP ONE
To Restore Default Start Menu Shortcuts used by Current User Only
NOTE: All 32 bit and 64 bit editions of Vista have these same single current user default Start menu shortcuts. You will also need to download the All Users Default Shortcuts for your edition of Vista in STEP TWO below.
Single_User_Shortcuts.zip
download
2. Save the Single_User_Shortcuts.zip file to the desktop.​
3. Right click on the Single_User_Shortcuts.zip file (on desktop) and click on Open.​
4. Click on Allow in the UAC prompt.​
5. Extract the Single_User_Shortcuts folder to the desktop.​
6. Right click on the Start button and click on Open or Explore, not Open/Explore All Users. (See screenshot below)​
NOTE: This will open this hidden Start Menu folder in Windows Explorer:​
C:\Users\(user name)\AppData\Roaming\Microsoft\Windows\Start Menu
7. To Restore All Default Single User Start Menu Shortcuts
A) Open the Single_User_Shortcuts folder (on desktop) and right click on the Programs folder and click on Copy.​
B) Right click on a empty space in the Windows Explore window and click on Paste. (See screenshot above)​
C) Click on Yes and Copy and Replace to confirm the copying of the default shortcuts and desktop.ini files.​
8. To Restore Just the Single User Shortcuts You Want
A) Open the Single_User_Shortcuts folder (on desktop) and manually copy the shortcuts you want over to the Start menu location in the Programs folder in the Windows Explorer window location above. (See screenshot below step 6)​
STEP TWO
To Restore Default Start Menu Shortcuts Shared by All Users
NOTE: You will just need to select the download for your edition of Vista. You will also need to do STEP ONE above to restore the Single User default Start Menu shortcuts.
1. For Vista 32 bit or 64 bit Home Basic
All_Users_Home_Basic.zip
download
B) Go to step 5.​
2. For Vista 32 bit or 64 bit Home Premium
All_Users_Home_Premium.zip
download
B) Go to step 5.​
3. For Vista 32 bit or 64 bit Business
All_Users_Business.zip
download
B) Go to step 5.​
4. For Vista 32 bit or 64 bit Ultimate
All_Users_Ultimate.zip
download
5. Save the ZIP file to the desktop.​
6. Right click on the ZIP file (on desktop) and click on Open.​
7. Click on Allow in the UAC prompt.​
8. Extract the All_Users_(Vista Edition) folder to the desktop.​
9. Right click on the Start button and click on Open All Users or Explore All Users, not Open/Explore. (See screenshot below)​
C:\ProgramData\Microsoft\Windows\Start Menu
10. To Restore All Default All Users Start Menu Shortcuts
A) Open the All_Users_(Vista Edition) folder (on desktop) and highlight the Programs folder, Default Programs shortcut, and Windows Update shortcut, then right click on them and click on Copy.​
11. To Restore Just the All Users Shortcuts You Want
A) Open the All_Users_(Vista Edition) folder (on desktop) and manually copy the shortcuts you want over to the Start menu location in the Programs folder in the Windows Explorer window location above. (See screenshot below step 9)​
  • All_Users_Home_Basic.zip
  • All_Users_Home_Premium.zip
  • All_Users_Business.zip
  • All_Users_Ultimate.zip
  • Single_User_Shortcuts.zip
I love you. Thank you very much. That was very useful. Unlike the Microsoft website.
    Intel Core 2 Extreme Quad-Core Processor QX6850 (4x 3.0GHz)
    Asus Striker Extreme nForce® 680i SLI Chipset
    4096MB DDR2-800 PC6400 Memory Module Mushkin High Performance II
    NVIDIA GeForce 8800 Ultra 768MB w/DVI + TV Out Video
    Creative Lab Sound Blaster X-Fi Platinum Fatal1ty Champion
    LCD Monitor ViewSonic 19"
    1024x768
    1.5TB (750GB x2)
    Nzxt Hush Gaming Tower Case
    Thermaltake MaxOrb CPU Cooling Fan System Kit
    Logitech G15 Gaming Keyboard
    Razer Diamondback Plasma Edition Gaming Mouse
    1 GB Down/ 1.5GB Up
    Meter Display ( Thermal Temperature LCD Display Black )
    Flash Media Reader/Writer ( 12-In-1 Internal Flash Media Card Reader/Writer Black )
    TV Tuner ( External TV-Tuner w/Remote Control )
You're welcome Joseeg12, and welcome to Vista Forums.
    1TB Samsung 990 PRO M.2,
    4TB Samsung 990 PRO PRO M.2,
    Galaxy S23 Plus phone
THANK Y O U....been trying to figure repair out for days.
jakeers
    HP Pavilion a6407c-b
    AMD Athlon 64 X2 dual core processor 4400+
    hp w2007
    hp w2007 1680x1050
    yup, black one. kinda dusty though.
    yup, leave windows open all the time.
    yup, black and grey
    yup.. little one.
    mouse speed in negative terms
You're welcome Jakeers, and welcome to Vista Forums.
Hi Brink,
Many thanks for this tute, it works wonders for me, but not for long. It seems after every reboot the icons delete themselves again!
I have just done a fresh install of v.Ultimate with no more apps that i used to have one on the previous install (before i had the problem) the only thing different is Nero 9.
I have noted you have said a program may cause this to happen, have you any suggestion what type of program may have caused this? or why this may occur?
Is this going to be a case of a system restore?
Many Thanks, Chris
Hello Chris, and welcome to Vista Forums.
It could be a number of programs that could cause this. From a registry cleaning program that was allowed to remove registry entries it should not have, or any program that affects the Start Menu shortcuts (almost all of them).
I would say that it may be faster to try a System Restore using a restore point dated before this problem to see if it can fix it.
Thanks for the info Shawn, strage what has happened. Going to try a re-install, i was having some driver issues at the beginning (not encountered before) so will see what happens from here
Ok Chris. Please let us know how it went.
Hi Shawn/Everyone
Clean Re-install worked a treat, this time i didn't experince any driver issues, they just seemed to install. Got all my programs on and this time no issue. I think it may have been when i ticked a box for Shortcuts ALL USERS during an installation process [Poss Nero9].
So thumbs up
Thanks for your help
You're welcome Chris. I'm happy that this installation round went smoothly for you.
Hello ccyto, and welcome to Vista Forums.
It's the blue button with Download written on it just below the step that you wanted to download that file for. ;)
Thanks, Great work
    hp
    Intel Core 2 QUAD 2.40 GHz
    nVidia - 9500 GS
    SAMSUNG
    700 GB
    HP
    HP
    1 MB
You're welcome Top Secret. :)
Thanks shawn for an excellent and easy to follow disucssion of the problem - solution worked 1st time! Many thanks!
    HP 8510p Laptop
You're welcome Chiswm, and welcome to Vista Forums. :)
I tried the solutions posted on the 1st page. The reason: My Accessories folder is gone.
I tried the solutions but I still don't see the Accessories folder in my Start Menu. The apps in it, like Disk Cleanup and Disk Defragmentation are still there..somewhere in my computer if i use the search function.
My ProgramData is hidden and Accessories folder can still be seen (after I unhide it).
I thought I need to restart so restarted my computer. But there's a shellclassinfo notepad which appeared. I tried to delete it off from my start menu but it just won't delete itself.
Help!
I don't want to reinstall Vista.
