Power Options and Sleep Mode Problems
How to Troubleshoot a Vista or Windows 7 Sleep Mode Problem
This will show you some steps to help you troubleshoot and find out what is causing your sleep mode problem. These are the usual reasons for sleep mode problems. For more information, see: Windows Help and How-to: Turn Off a Computer FAQs
  • When your computer is in hibernation, the only way to wake it is to tap the case power button.
  • If this sleep mode problem just started recently, then you might consider doing a System Restore before or after trying the steps below if they do not help.
Common Problems:
  • Computer will wake up for no reason.
  • Sleep mode does not work any more.
  • Hibernate option is not available in Power Options, then you accidentally deleted the Hibernation file Cleaner in Disk Cleanup.
  • Screen saver not working.
BEFORE STARTING:Make sure you have the latest device drivers and BIOS installed for your motherboard.NOTE: A out-of-date video driver or other drivers are sometimes the source of sleep mode problems. It is best to keep these up to date to resolve issues found with them.
STEP 1
Check Your Mouse and Keyboard
NOTE: A wireless mouse and keyboard can cause your computer to wake up for no apparent reason, and to not wake up from sleep mode when you press a key or move the mouse. This may also cause your screen saver to not work to. If the computer is using an optical mouse, changes in light can cause the computer to wake.
For a USB Mouse or Keyboard:
1. Check the BIOS settings to make sure that you have a Legacy USB option enabled.​
For a Wireless Mouse or Keyboard:
1. Unplug the receiver on the back of the computer and test.​
2. If sleep or hibernation works now, then try:​
A) Download new drivers for you wireless mouse and test again with the receiver plugged in.​
NOTE: Always get your drivers from the source, never from Windows Updates. They do not work properly sometimes.
B) Disable the wireless mouse and/or keyboard wake up option in Step Five below. If you have to disable both of them, then you can wake the computer up by pressing the power button on the case.​
C) Time to get a new mouse and/or keyboard that is compatible with Vista.​
For a Optical Mouse:
1. Try not to have direct bright light shining on the sensor or moving around it.​
STEP 2
Check Advanced Power Plan Settings
NOTE: Power settings control the computer’s ability to go into and come out of sleep/standby mode.
2. Click on the Power Options icon.​
3. Click on the Change plan settings link under your power plan. (See screenshot below)​
4. Click on Change advanced power settings. (See screenshot below)​
5. Click on Change settings that are currently unavailable. (See screenshots below step 10)​
NOTE: This will allow any Power Options that are grayed out to now work and not be grayed out.​
6. Recommended Settings for Sleep
NOTE: Sleep saves any open documents and programs to memory only, and then puts the computer into a low-power state.
WARNING: If you lose power to the computer, you will also lose what is in memory.​
Main Setting
Sub Setting
Recommendation
Hard disk
Set to at least 1 minute before the computer (Sleep after setting below) is set to sleep.
Sleep
Sleep after
This is for the computer. Set to at least 1 minute after Hard disk and Display is set to turn off.
Sleep
Allow hybrid sleep
Set to Off.
Sleep
Hibernate after
Set to Never.
USB settings
USB selective suspend setting
Set to Disabled.
Power buttons and lid
Start menu power button
Set to Sleep.
PCI Express
Link State Power Management
Set to Off.
Display
Turn off display after
Set to at least 1 minute before the computer (Sleep after setting above) is set to sleep. Usually set this as the same as the Hard drive is set to turn off.
Multimedia settings
When sharing media
Set to Allow the computer to sleep.
7. Recommended Settings for Hybrid Sleep
NOTE: Hybrid sleep saves your open documents and programs to memory and to the hard drive, and then puts the computer into a low-power state. After the Hibernate after time you set, it will then put the computer into hibernation.
WARNING: Use the same Recommended Settings for Sleep in step 6 above, except for these changes:​
Main Setting
Sub Setting
Recommendation
Sleep
Allow hybrid sleep
Set to On.
Sleep
Hibernate after
Set to at least 1 minute after the computer (Sleep after setting above) is set to sleep.
8. Recommended Settings for Hibernation
NOTE: Hibernation is a power-saving state that saves your open documents and programs to the hard drive and then turns off your computer. If Hibernate after is not listed, then make sure that you have the Hibernation File enabled or restored to. It is by default unless it was cleaned in Disk Cleanup.​
Main Setting
Sub Setting
Recommendation
Sleep
Sleep after
Set it to Never.
Sleep
Allow hybrid sleep
Set it to Never.
Sleep
Hibernate after
Set it to at least 1 minute after Hard disk and Display is set to turn off.
Set it to Hibernate.
9. Click on OK to apply​
10. Just exit out the other windows.​
11. Test sleep mode. If it is still not working correctly, then continue to the next step.​
STEP 3
Check Sleep State Settings in BIOS
NOTE: Make sure you have the latest Video drivers and BIOS for your motherboard. Read your motherboard manual to see if you have any jumpers or settings that sets different sleep voltages for USB.
1. Open the Start Menu.​
2. In white line (Start Search) area, type cmd and press Enter.​
3. In command prompt, type powercfg -a and press Enter. (See screenshot below)​
NOTE: This will give you a report of the available sleep states for your computer and will attempt to report reasons why sleep states are unavailable. You will want to see if the ACPI S1 and/or S3 is listed.
4. Restart the computer into the BIOS settings, and go into the Power Management section in the BIOS.​
NOTE: Usually you will press the F2 or Delete key as soon as your computer starts booting to enter the BIOS.
5. Make sure ACPI mode: S3 or S1 is enabled.​
WARNING: S1 (Sleep) and S3 (Hybrid deeper sleep). If you are running an incompatible video card, some or all of these states below may be unavailable. If one of the settings causes your computer to not wake back up afterwards, then reset the CMOS on the motherboard and restart the computer, or unplug the computer for a moment and plug it back in, and reset the BIOS back to the factory default settings.
6. Make sure Wake on Ring and Wake on Lan are disabled.​
NOTE: This will help keep the computer from waking up on its own.​
7. Save the BIOS setting changes and exit to restart the computer.​
8. Test sleep mode. If this does not help, then move on to the next step.​
STEP 4
To See what had Waken Up Windows Last
NOTE: This will give you a list of items that woke up the computer last that may help narrow down what is waking up the computer.
3. In command prompt, type powercfg lastwake and press Enter. (See screenshot below)​
NOTE: Notice that I had USB\ROOT\HUB listed. For me, this would be the USB wireless mouse. Your list results will vary of course.​
STEP 5
To List, Enable, or Disable Device Names Currently Configured to Wake Up the System From any Sleep State
NOTE: This will show you a list of devices that are able to wake up your computer to help you narrow down a device that may be responsible for waking up your computer. It does not mean that these devices are the ones that woke up your computer though, just that they are able to.
2. To List Devices that Can Wake Up the Computer
A) In the command prompt, copy and paste in bold: (See screenshot below)​
powercfg -devicequery wake_armed and press Enter.​
B) Go through the list of devices to see if you have one you do not want to wake up your system.​
EX: A Network Device (Modem, Ethernet, etc.) or Wireless Mouse.​
C) If you found a device that may be causing the problem, then check with the STEP SIX section below first to see if you can disable a wake up option for the device in it's Power Management settings in Device Manager to test to see if that is it before proceding.​
3. To Disable a Listed Device From Waking Up the Computer
NOTE: Only do this step if you cannot do it from STEP SIX below using Device Manager instead.​
A) In the elevated command prompt, type below in bold and press Enter.​
WARNING: Be sure to write this device name down in case you want to be able to enable it again in step 4. Once you disable it, it will not be listed again in step 2A until enabled again.​
powercfg -devicedisablewake "exact name of device listed in step 2A"
NOTE: For example, if I wanted to disable the listed (step 2A) High Definition device (HDAC), then I would type powercfg -devicedisablewake "High Definition Audio Controller" and press enter.​
4. To Enable a Listed Device Again to Waking Up the Computer
NOTE: Only do this step if you cannot do it from STEP SIX below using Device Manager instead, or you have done step 3 above with the device.​
powercfg -deviceenablewake "exact name of device listed in step 2A"
NOTE: For example, if I wanted to reenable the High Definition device (HDAC) that was disable and removed from the list in step 3, then I would type powercfg -deviceenablewake "High Definition Audio Controller" and press enter.​
5. When done, close the elevated command prompt, and test sleep mode.​
STEP 6
To Disable or Enable the "Allow this device to wake the computer" Option for a Device
  • Check your Network device. Network activity can cause the network hardware to wake the computer, especially when the network is always on (like cable and DSL connections).
  • High Definition Audio, if listed in STEP FIVE, may also rarely cause the computer to wake from sleep mode. You can disable (only option available) the device as a test in Device Manager to see before putting the computer to sleep. Just enable it again if it is not the problem.
2. Click on the Device Manager icon.​
NOTE: You need to be in a Administrator account.
4. Open the device's list that you want to change. (See screenshot below)​
EX: Network Devices
5. Right click on the device name and click on Properties.​
EX: Network Devices
6. Click on the Power Management tab. (See screenshot below)​
7. Uncheck Allow this device to wake the computer. (See screenshot above)​
NOTE: To Enable it again, just check this instead. If you need to disable the wireless mouse and keyboard, then you can wake the computer by pressing the power button on the case.
8. If listed, check Allow the computer to turn off this device to save power. (See screenshot below step 6)​
NOTE: This will turn the device off when the computer goes into sleep mode.
9. Click on the Advanced tab. (See screenshot below)​
NOTE: This is only for the Network device.
10. Check the boxed in red Property: items below to see if they are set to Disabled in the Value: area. (See screenshot above)​
NOTE: This area may be different for your particular network device since it is based on the driver, but it should be similar. You will be looking for any Wake on type property options listed.​
11. Click on OK to apply and close properties window. (See screenshot below step 6 or 9)​
STEP 7
Check the Screen Saver
NOTE: Some screen savers can interfere with the computer’s ability to go into and come out of sleep/standby mode. Disabling or changing the screen saver may resolve the problem.
1. In the Screen saver settings, select an alternate screen saver, or set it to None, then click on OK.​
2. Test sleep mode.​
STEP 8
Check Startup Programs
  • Many software components start up automatically with Vista and run in the background. Some of these programs may not be necessary, and can interfere with the sleep/standby mode. For troubleshooting purposes, use the following steps to prevent programs from starting up with Vista to see if this is the issue.
  • If you are having these problems, you can avoid from having to do this completely if you logoff and put the computer to sleep from within the logon screen.
A) In the white line (Start Search) area, type msconfig and press Enter.​
B) Go to step 3.​
OR
2. Click on All Programs, Administrative Tools, and System Configuration.​
4. Under the General tab, dot Selective startup. (See screenshot below)​
NOTE: When done with the test, dot Normal startup, to return to the default settings before the test, and click on OK.
5. Uncheck Load startup items and click on OK and restart the computer.​
NOTE: You will get a notification that you made changes to the Startup programs in the bottom right Notification area. Just ignore it for now. It will go away when you put it back to Normal startup after you finish.
6. Test sleep mode.​
7. If unchecking (disabling) Load startup items fixed the sleep problem, then enable one startup item at a time and test to see if the problem occurs again. Continue enabling startup items, until you find the program that is causing the problem. Remove or update the problem program.​
NOTE: See Method One or Two here: How to Check and Change the Startup Programs in Vista
A) When done, change the setting back to Normal startup (step 4).​
8. If unchecking (disabling) Load startup items did not resolve the sleep problem, then set it back to Normal startup (Step 4) and go to the next step below.​
STEP 9
Check Scheduled Tasks for Programs
NOTE: Sometimes a program will have something scheduled to run that will wake the computer up. Try turning them off temporarily to see if it resolves the problem.
1. Check in the suspected program settings to see if there is a feature that may wake the computer.​
NOTE: Sometimes it can be the Auto-Update feature in the program.​
2. Check Task Scheduler for items that are set to Wake-Up the computer to perform it's action.​
A) Expand out the list in the left pane and click on the suspect item's folder. Double click on the task in the middle pane.​
B) Click on the Conditions tab.​
C) Uncheck the Wake the computer to run this task box.​
3. Check Windows Automatic Updates settings.​
STEP 10
Check Windows Sidebar Gadgets
NOTE: Sometimes a Windows Sidebar Gadget may cause the computer to not sleep on it's own.
1. Turn off Windows Sidebar as a test to see if your computer will enter sleep on it's own now.​
NOTE: Sometimes, you may need to restart the computer afterwards as well.​
2. If it does, then turn Windows Sidebar back on and turn off each Gadget one by one. Test sleep again after each one until you find the one causing the problem.​
STEP 11
Check Motherboard Jumpers
NOTE: A few motherboards have been reported has having jumpers on the board for certain functions (ex: USB device wake-up) that may need to be enabled or disabled.
1. Pull out or download your motherboard manual, and check for any such jumpers.​
2. If you have one that is related (ex: USB device wake-up), then test sleep mode inbetween toggling the jumper on and off.​
STEP 12
Reset Print Spooler
NOTE: This may help if your computer will sleep fine manually, but will not sleep automatically or not go to sleep at all. Credit to Artxie for this.
1. Open Services, and temporaily Stop the Print Spooler service.​
2. Open the Start Menu and type %WINDIR%\system32\spool\printers in the search line and press enter, then delete all files in this folder.​
3. In Services, Start the Print Spooler service. Close Services window.​
If the print spooler issue persists, the installed printer driver may not be compatible or corrupted. Check the printer manufacturer's website to download and install the latest Windows compatible driver for it.
STEP 13
Enable or Disable Windows Media Center Updates to Wake Up the Computer
NOTE: This will show you how to enable or disable the Windows Media Center (mcupdate) task from waking up the computer from sleep when it checks for Media Center updates in Windows 7 and Vista.
STEP 14
View and Override Power Availability Requests
By using power availability requests, applications, services, and drivers can temporarily disable power management features to accomplish user scenarios. Availability requests can prevent the display from turning off after inactivity, and prevent the computer from automatically sleeping, enable Away Mode, and shutting down.
STEP 15
Try System Restore
NOTE: If sleep/standby mode previously worked, attempt a system restore back to a time when it worked. If the problem has always existed, skip this step.
1. Save any open files and close all programs, then backup anything that you do not want to lose to be safe..​
NOTE: If System Restore resolves the problem, the problem is probably caused by software that was installed after the restore point date.
I hope this helps,
Hi crashnet,
That's a good idea. It has been added to Step Seven in the tutorial.
Thank you,
you're welcome! BTW you should add a DIGG button to this page...
BTW i ran thru all the steps, but i still can't get it to wake up. running vista ultimate x86 sp1 with all the drivers up to date...
    Lenovo Thinkpad T60
    T7200 2Ghz
    2Gb
    Cable
crashnet,
Do you have a wireless mouse or keyboard? When you ran Step Four, was the keyboard or mouse listed as allowed to wake the computer up?
Have you checked by switching the BIOS S1 or S3 settings?
Add any more details that you think may help to.
    1TB Samsung 990 PRO M.2,
    4TB Samsung 990 PRO PRO M.2,
    Galaxy S23 Plus phone
there is no choosing between S1 or S3 in the BIOS.
i do have a wireless mouse an keyboard, and i set them to NOT wake up the computer - i can do it from the laptop keyboard. but i dont think they are the problem cause it doesnt wake up even when i have both of them unplugged.
i have a lenovo T60-6371 with all the latest drivers and BIOS. i can hibernate fine, but it never wakes up from sleep correctly. it seems that it is about to wake up (num lock and caps lock flash, fan comes on) but the screen never shows anything. when i first got it from factory it did sleep fine, so i dont think my problem is cheap non acpi compliant hardware (not to be expected in a thinkpad anyways).
one would think it would be a video driver issue, but i've been thru three incarnations of them. the current driver for the GMA950 (945 Express Chipset Family) is 7.14.10.1329.
thank you
    Lenovo Thinkpad T60
    T7200 2Ghz
    2Gb
    Cable
thank you
That's a nice machine. I used to have one, then I changed jobs. :(
Is there a BIOS option for "repost video on resume" or something like that? That might help.
Also, have you tried an external monitor? Does that work?
thank you
crashnet,
I always had to press the case power button to wake the computer up from hibernation. Only if I put the computer to just Sleep will it wake up from the keyboard or mouse.
This is just something to try to see if you may just have a corrupted Hibernation file. Afterwards, see if helped with having a fresh clean hibernation file.
1. Run Disk Cleanup and check Hibernation file Cleaner and click OK.
This will wipe it out clean.
2. Restore the hibernation file. You can see how here:
http://www.vistax64.com/tutorials/63567-power-options-sleep-mode-problems.html
i've tried with and without an ext monitor. and there is nothing similar to that in the BIOS.
hibernation never failed, but i cleared the file anyways. didnt help with the sleep...
thanks!
    Lenovo Thinkpad T60
    T7200 2Ghz
    2Gb
    Cable
crashnet,
Yes of course. The USB is powered completely off along with everything else when the machine hibernates.
I just thought of something else. The kosher way to wake a Thinkpad from sleep is to hold the "Fn" button on the keyboard (or open the lid unless you've disabled that). IIRC you can use the Thinkpad Keyboard Customizer Utility to map "Fn" to a key on an external keyboard. This might enable wake up from the external keyboard.
Here's the utility:
Vista: Lenovo Support & downloads - Keyboard Customizer Utility for Windows Vista - ThinkPad
XP/2000: Lenovo Support & downloads - Keyboard Customizer Utility for Windows 2000, XP - ThinkPad
thanks, but i just want to wake it up successfully. trying to wake it up from an external keyboard is only introducing an extra layer of complexity.
BTW, hibernation doest work anymore either. when i select hibernate, it seems that it will happen (screen goes blank then it writes to disk) but then it beeps and i am back at the welcome screen. i read elsewhere that this problem can be related to the january 8th updates, but at the same time some people say this problem happens after re partitioning with partition magic, which i did do and as far as i can recall is what caused the problem for me. drive C IS marked as the active partition.
    Lenovo Thinkpad T60
    T7200 2Ghz
    2Gb
    Cable
My hybernate and sleep were working fine until I installed a new sound card M-Audio Delta 66. I have installed the latest vista drivers for it.
When my computer tries to sleep the monitor goes blank, but I still hear the hard drive and cpufan still going.
If I disable the device in the device manager, it lets my computer sleep.
I hate to have to disable and reinable this everytime I want to use the device (audio recording). Is there a work around for this?
Thanks!
Hi faudramsey,
From what I read on that audio board, there is some sort of sleep mode support issue with the drivers still. I would contact M-Audio support to see if they have a solution in the works that you may be able to try.
M-AUDIO - Contact Tech Support#
Does it work ok if you were to uninstall the drivers in Device Manager and use the default one's that Vista gives it?
Sorry, :(
just an update: a recently release lenovo power manager patch solved my laptop's sleep problems.
thanks to everyone for the help
    Lenovo Thinkpad T60
    T7200 2Ghz
    2Gb
    Cable
That's great news crashnet. It's about time Lenovo started releasing some patches. Now all they need to do is resolve their chkdsk issue. ;)
whats the chkdsk issue?
    Lenovo Thinkpad T60
    T7200 2Ghz
    2Gb
    Cable
There have been alot of Lenovo owners reporting that they cannot get chkdsk (Check Disk) to run at startup on their computers no matter what they tried.
Hi Hachi,
Welcome to Vista x64 Forums. :party:
I agree with Starlionblue. If your on the computer all day like me, then the High Performance power plan is the way to go. You can always adjust the settings in that power plan down a bit if you wanted to also.
Why save power if you're plugged in?
that's a selfish statement. because electricity is the #1 source of greenhouse gases. because the nation's power grid, climate change aside, is struggling to keep up with demand. because wasting is not a good thing to do.
you don't have to "believe" in anything to realize it is wise to try to reduce your footprint (of greenhouse gases emission). watch this video:
[youtube]mF_anaVcCXg[/youtube]
then come back here and tell me if you can poke a hole in this theory.
aside from all the altruistic reasons above, there is one more selfish reason to add to the pile: you might close to double the life of your hard drive if you let it spindown as opposed to keep it running 24/7
    Lenovo Thinkpad T60
    T7200 2Ghz
    2Gb
    Cable
Hi all!
It's me again ;)
Well, I've problem installing Flash player in Vista64 and I found some info here and in Google.
Following some info I've found with Disk cleanup that I have 8 GB As hybernation file cleaner!!!!!
I'm trying to understand how this power setting are....but 8 GB ..... I think it's unacceptable.
My pc is always running, and sometimes go to sleep.....
Can I erase that 8GB ?
Sorry for my bad english and thanks in advance
lio
PS I found now this:
my understanding of hibernation is that it's the size of your physical ram...
And I've 8 GB of RAM....... but it's absolutely crazy!!!!!!!
