Logon Automatically
How to Log on Automatically at Startup in Vista
This will show you how to set or change a user account for Vista to automatically log on to at startup. By default all user accounts must log on at startup.
  • If you only have one user account without a password on your computer, then Vista will logon to that account automatically at startup.
  • If you have more than one user account and the one you want to have Vista logon to automatically at startup does not have a password, then leave the password fields blank in step 7 below.
  • If you forgot or lost the password for a user account, then see: How to Reset a User Account Password in Vista
  • If your computer is a member of a domain, then the check box for Users must enter a user name and password to use this computer will not be available. It will be grayed out instead.
Be sure to enter the correct password for the selected user account to have Vista automatically log on to at startup. If this user account does not have a password, then leave it blank. If you change the user account password, be sure to change it here as well. If you enter or have a incorrect password for this user account you will get a Incorrect Password error at the next startup. When you click OK to this at the logon screen, you will then see a duplicate logon icon for this user account. You can fix this problem by loging on to another account, or boot into Safe mode, and change the password to the correct one in step 7 below and restart again.
EXAMPLE: Log On Screen
NOTE:
With Automatic Log On, you will not see this anymore. Vista will boot into the desktop of the selected user account instead.
1. Open the Start Menu.​
2. In the white line (Start Search) area, type netplwiz or control userpasswords2 and press Enter.​
NOTE: It is your choice on which one to type. They both open the same window.
4. To Turn On Automatic Log On for a User Account
A) Check the Users must enter a user name and password to use this computer box. (See screenshot below step 6)​
B) Click on the user account name, that you want to have automatically log on at startup, to highlight it.​
C) Uncheck the Users must enter a user name and password to use this computer box.​
D) Click on OK.​
E) Go to step 7.​
5. To Turn Off Automatic Log On
B) Click on OK.​
C) Your done.​
6. To Choose a Different User Account to Automatically Log On to
NOTE: For this step, you would have already had a user account selected to log on to automatically in step 4.​
A) Check the Users must enter a user name and password to use this computer box. (See screenshot below)​
B) Click on Apply.​
C) Select the other user account name, that you want to have automatically log on at startup instead, to highlight it.​
D) Uncheck the Users must enter a user name and password to use this computer box.​
E) Click on OK.​
7. Enter the User Account Password
A) In the Password field, enter the selected user account's password. (See screenshot below)​
NOTE: If the user account does not have a password, then leave this field empty. See the WARNING at the top of the tutorial.​
B) In the Confirm Password field, enter the selected user account's password again to confirm that it is the same as in step 7A.​
NOTE: Be sure to enter the correct password for this user account. If this user account does not have a password, then leave it empty. See the WARNING at the top of the tutorial.
C) Click on OK.​
I used this method, and it works fine. However, when I log off (not shut down), in order to log in as Admin, I am unable to enter a password. The mouse works fine, but it seems like the keyboard isn't working at that point.
It's a normal USB keyboard, and works on bootup and at all other times. But when I click on the password box, and type, no text is entered.
Any ideas? I'm sure it's not supposed to be like this after adding the auto login, right?
Hi Rick,
I'm not sure why your keyboard would not be working. Might try switching keyboards to test.
    1TB Samsung 990 PRO M.2,
    4TB Samsung 990 PRO PRO M.2,
    Galaxy S23 Plus phone
Re: Log On Automatically
Updated to include multiple accounts and how to change between them.
Thanks for the guide mate ^^
    Q6600 OCed till 3.3Ghz
    Nvidia XFX nForce 780i SLI
    2X2GB Corsair DDR2 800Mhz OCed @ 820Mhz
    2xNvidia 9500 GT SLI OCed @ 730Mhz each.
    Motherboard Built in
    Acer 22' LCD + 18.5 Wide Samsung LCD
    Internal 2x250 GB SATA II Maxtor,
    External 500GB SATA WD,
    600Watts
    GIGABYTE
    GIGABYTE Volar CPU Cooler
    Samsung Pleomax
    Prestigio
    2Mbps
I always hated having that screen
as sometimes it was slow to come up
I didn't even have a password set so I didn't see a reason to have it up lol
I always tell people about your tutorials who have vista and a problem :p
yours are easy to follow :)
    Acer Aspire 7730
    Intel(R) Core(TM)2 Duo CPU T5800 @ 2.00GHz, 2
    UMA
    Dolby(R) Surround Sound
    HD Flat.
    Resolution 1440 x 900 x 59 hertz
    160 GB
    Split in two, Data drive, Personal Drive, 69.5 GB each.
    Lithium Ion 6 cell Battery life 2.5 hours
    Gloss black, Plastic.
    Fan on the back and underneath.
    Built In
    Touch Pad
Your welcome Sound_Asleep.
Thank you. I try to make them easy with every step included. I always welcome any input from people on how they think something would make them easier to do or follow.
well I can't think of anything to make the guide easier
that guide was like
15seconds when actually doing it to my laptop :)
:D
    Acer Aspire 7730
    UMA
    HD Flat.
    160 GB
    Built In
    Touch Pad
ufff... when i logon an image apears (changed by me with Logon studio vista) and in the middle of the image appears "OK" in a box and until i don`t click the "OK" vista won`t logon... what is wrong with my vista?
    e6300
    asus p5l 1394
    4.oo GB
    asus EAH 4650
    audigy soundblaster
    LG L1919s
    Western Digital - WDC WD800AAJS-00WAA0 (74 GB)
    Western Digital - WDC WD1600JS-00NCB1 (149 GB)
    Microsoft
Hello Giksy,
Strange, is that all it says is "OK"?
Do you have automatic logon set? If you do, then you might toggle it on and off to see if that helps.
not exactly, in the upper left corner i wrote something there "welcome to vista" and in the middle is the OK
and yes i have the automatic logon set. i`ve done that twice
    e6300
    asus p5l 1394
    4.oo GB
    asus EAH 4650
    audigy soundblaster
    LG L1919s
    Microsoft
Giksy, it sounds like you may have entered the incorrect password while setting up automatic logon as in the Warning box at the top of the tutorial. You might check this by doing the automatic logon setup again.
i haven`t entered any password
    e6300
    asus p5l 1394
    4.oo GB
    asus EAH 4650
    audigy soundblaster
    LG L1919s
    Microsoft
As a test, go ahead and create a password for that account, then set automatic logon again with that account's password to see if that helps.
i reinstalled my vista. anyway thank you very much! and again thx for the very helpful forum!
    e6300
    asus p5l 1394
    4.oo GB
    asus EAH 4650
    audigy soundblaster
    LG L1919s
    Microsoft
No problem Giksy. I suppose that's one way of fixing it. ;)
Hi
I have just received a laptop with Vista on it so you will have to excuse my somewhat limited knowledge so far :)
More on topic, is there any way you can have it log in but only after x seconds?
So auto-login to guest account 15 seconds after welcome screen if no buttons pressed or something to that effect?
Regards,
~John
Hypothetically, if I set this and I then have a problem with my User Account, how could I log into a different one on boot like the Administrator account?
    Windows Vista Home Premium SP2, 32-bit
    Retrofitted Refurbished Gateway
    AMD
    ASUS M3A78-EM
    Acer 22-in Flat Screen Monitor
    Logitech K350 Wireless Keyboard
    Logitech M705 Wireless Mouse
