Activate Vista by Phone
How to Activate Vista Normally and by Phone Activation
This will show you how to activate Vista normally, and by using Phone activation. Phone activation is used to get a local phone number to call and get Vista activated by phone.
For more information, see:
A Express or Retail Vista can be installed on any one computer at a time for as many times as you like. A OEM Vista may only be able to be installed on the exact same computer as many times as you like. The product key number for the Vista 32 bit version is the same one for it's 64 bit version. You can only have the Product Key activated on one computer and version of 32 bit or 64 bit Vista at a time.
See: Microsoft: License Terms for Software Licensed from Microsoft
  • Microsoft no longer provides support for preinstalled OEM (recovery) copies of Vista. If you have one of these, then you must contact the OEM, instead of Microsoft in this tutorial, to activate your OEM Vista. OEM contact information should be included in the documentation that came with your computer or OEM Vista installation CD/DVD package.
  • A OEM (retail) version Vista installation DVD that is bought separately and did not come preinstalled on a OEM computer is still supported by Microsoft using the method in this tutorial below.
  • You only have 30 days of trial period to activate Vista, 3 days if you checked the Automatically activate Windows when I'm online while installing Vista. If you let the trial period expire, you will be placed into a Reduced Functionality Mode until you activate Vista. When you activate Vista, the product key number used will be tied to that computer. If you make significant changes to the computer, like a new motherboard, you will be required to do a Phone Activation. If you want to use it on another computer, then you must uninstall it from the other computer first and do a Phone Activation on the new computer. This is to verify that you are using the product key on only one computer.
ERROR MESSAGES:
For more information, see: Microsoft Help and Support: KB931276 and Microsoft Help and Support: KB951287
  • The Windows Vista product key you typed is invalid for activation.
  • Your Product Key is already in use.
  • Windows Activation Error: A problem occurred when Windows tried to activate. Error Code 0x8007232B
  • Activate Windows Now
  • Your activation period has expired and Windows is no longer working.
  • To use Windows you must activate this copy of Windows.
  • Etc....
There has been a update for this through Vista's Windows Update to help with frequent prompting to activate Vista. If this applies to you, be sure to download the correct 32/64 bit version for your Vista.
See: Microsoft Help and Support: KB931573 Update
EXAMPLE: Product Key Number on COA Sticker
NOTE:
The product key number has 25 characters in it.
EXAMPLE: Vista not Activated
WARNING:
The Product ID number displayed here is not your Product Key number.
EXAMPLE: Vista Activated
WARNING:
STEP ONE
Try to Activate Vista Online Normally
NOTE: If you have a valid license for Vista, then double check that you entered the product key number correctly.
1. Open the Start Menu, and right click on Computer and click on Properties.​
A) Go to Step 3.​
OR
2. Open the Control Panel (Classic view), and click on the System icon.
3. Scroll down to the bottom and you will see this screenshot. (See screenshot below step 5B)​
4. Click on the Activate Windows now link.​
A) Go to step 6.​
5. If it will not activate, then click Change product key.​
A) Type in the product key again to make sure it is correct.​
NOTE: You can also use this if you just want to change it to a different product key for the same version of the installed Vista.​
B) Click on the Activate Windows now link.​
6. Click on the Activate Windows online now link. (See screenshot below)​
7. If Vista fails to activate, then proceed to step 2 below.​
STEP TWO
How to Do a Phone Activation
NOTE: On a preinstalled OEM Vista, you may need to call the manufacturer (Ex: HP) to get Vista activated again.
OPTION ONE:
1. Do the STEP ONE section above.​
2. Click Use the automated phone system to activate. (See screenshot below)​
A) Go to step 3 in OPTION TWO below.​
OPTION TWO:
1. Open the Start Menu.​
2. In the white line (Start Search) area, type slui.exe 4 and press Enter.​
3. Select your nearest location and click on the Next button. (See screenshot below)​
5. A local phone number should apear with a set of numbers generated by Windows and displayed on your screen under Step 2: . (See screenshot below)​
NOTE: There will be sets of numbers under the 1 to 9. I just removed them here for obvious reasons. ;)
6. Call the activation phone number selected.​
7. At first, the activation line will be automated, so you will be asked to enter or speak the numbers (Step 2 in screenshot below step 10) displayed on your screen into the phone.​
8. If Automated Service is Successful
NOTE: Usually this is not always successful.​
A) The automated service will issue you a set of Confirmation ID numbers.​
NOTE: Have a pen and paper handy to write these numbers down.
B) Go to step 10.​
9. If Automated Service is Unsuccessful
A) If the activation service informs you that it was unsuccessful and cannot help you with activation, then STAY ON THE LINE and your call will be transferred to an activation operator who will assist you in activating your copy of Vista. The operator will give you the set of Confirmation ID numbers if they agree your copy of Vista is legitimate.​
NOTE: Just explain to the operator your situation and what you did to require activation. (EX: hardware upgrade, installed Vista on a new computer after uninstalling it from the old one, etc...)
10. Type in the set of Confirmarion ID numbers given to you into the Step 3: area to be able to activate Vista. (See screenshot below)​
NOTE: You will get these numbers from the phone automated system or operator after they have confirmed the numbers you gave them in step 7 above.​
NOTE: The numbers in Step 2 of this screenshot will be there for you to use in step 5 above. I have just cleared them from this screenshot for obvious reasons. ;)
11. When you get the Activation was successful window, click on Close to finish. (See screenshot below)​
    1TB Samsung 990 PRO M.2,
    4TB Samsung 990 PRO PRO M.2,
    Galaxy S23 Plus phone
Hi Mch_Mntr,
Yes, you will get the Confirmation ID number from the phone activation automated system or operator when you call them.
Hi Jordan,
Only if you select a non toll-free number to use. ;)
Hi Mod Zezima,
I'm not sure where you are getting call for assistance from. After you click on Activate Windows online now, you would click on Use the automated phone system to activate to get the phone number. Be sure you are doing STEP TWO for a phone activation.
Hello HTMLCODER.exe, and welcome to Vista Forums,
Did you use the manual way with Option Two for the slui.exe 4 file. If you did, and this is the options you got, then you will need to contact HP to let them know you need help activating Vista with the OEM product key number that you have provided by them.
Hmm... the slui.exe 4 showed exactly the same options.
But... In past, I had to reactivate Vista couple of times, and I could use the phone for this. I have 4 days left; I guess I'll just waut for the reduced mode to kick in, then it maybe will show the phone options.
I have noticed that Microsoft has been stopping support for OEM versions where they use to help with phone activation before. I would contact HP before you get in reduced functionality mode to see what they say. They should be able to help you with their OEM activation as per their requirement and agreement with Microsoft.
Re: Activate Vista by Phone via manufacturer for new hard drive on old computer?
I hope it was okay to dredge up this old thread and ask for further clarification. And I hope someone will see it and respond. ;)
So I have a Dell XPS430 - about 4 years old with Windows Vista 64bit installed.
As near as I can tell the hard drive died and I'm buying a new hard drive tomorrow.
I have a Vista Home Premium 64bit SP1 Dell OS "reinstallation DVD".
Do I understand correctly that when I install my new hard drive on my XP430 I will not be able to install Vista because it is a new hard drive, even though it's the same computer?
Or am I to understand that I CAN do this, but I will have to call Dell and Dell WILL give me a new license key for the Vista install? And this disk is all I'll need to install it once I have that license key?
Sorry for the probably dumb questions but a) this is the first time I've had a hard drive die, ever; b) this is the first time I've had to install Windows and c) I have read a bunch of different threads on this subject and some seem to say I CAN install my OEM(?) Vista on my new hard drive/same computer and some say I cannot. Some say call MS and here you say call the computer manufacturer.
And d) this is a very old thread so maybe things have changed.
Can you clarify this for me? or refer me to another thread? (I did search the forum but did not find a thread other than this about this particular situation.)
Thanks in advance!
    DELL XPS 430
    Intel Core™2 Q8200 Quad-Core (4MB L2 cache,2.33GHz,133
    7200RPM, SATA 3.0Gb/s, 16MB Cache
    6GB Dual Channel DDR3 SDRAM at 1066MHz - 4 DIMMs
    ATI Radeon HD3650 256MB Graphics (Integrated)
    Integrated 7.1 Audio (IDT/Sigmatel 6.10.0.6017)
    Dell -1901FP Flat Panel LCD Color Monitor
    1024 x 768 32 bit
    750 gig SATA 7200 C drive
    External Seagate 160gig
    " Western Book 160 gig
    " Hitachi 250 gig
    ALL USB except C drive
    Logitech ITough Multimedia
    Microsoft Intellimouse Trackball - (best design ever made!)
    ATT Yahoo Elite DSL 4797kbps down, 624kbps up
Hello pdsnickles,
It's no problem at all. I'm sorry about your hard drive kicking the bucket.
You will still be able to install and activate on a new hard drive with the same product key number on the COA sticker. It's usually only when you replace the motherboard is when you run into activation issues since an OEM product key is permanently tied to the motherboard of the computer it was first activated on.
If you have any other questions, then please feel free to ask.
Hope this helps, :)
Thanks much, Brink. I appreciate your taking the time to answer.
    DELL XPS 430
    1024 x 768 32 bit
    " Hitachi 250 gig
You're always most welcome. :)
This is a follow up to my question about installing a new hard drive.
When I install the new hard drive, someone told me to add the drivers from the Dell page re my XP430 one by one with system drivers first.
However, I plan to restore the programs etc of the broken drive through an imageI took of it about a year ago.
So in that case, I do NOT have to add drivers at all, right? or do I?
Wouldn't the drivers be part of the image?
I'm not really sure as I have never used an image to restore before. (Created by a Paragon program.)
I would just add the software for Paragon through my new Windows install then restore the image, right? Or do I have to add the drivers first?
Hello pdsnickles,
Hope this helps, :)
    DELL XPS 430
    1024 x 768 32 bit
    " Hitachi 250 gig
An image would restore the complete Windows installation as it was when the image was created.
