System Restore Shortcut
How to Create a "System Restore" Shortcut in Vista
This will show you how to create a shortcut to the main System Restore window to make it easier to do a System Restore.
The default shortcut location in the Start menu is:
Start Menu\All Programs\Accessories\System Tools\System Restore
EXAMPLE: Shortcut opens this
OPTION ONE
To Download the "System Restore" Shortcut
1. Click on the download button below to download the System Restore.zip file.​
download
2. Click on Save, and save it to the Desktop.​
3. Right click on the System Restore.zip file (on desktop) and click on Open.​
4. Click on Allow in the UAC prompt.​
5. Extract the System Restore shortcut to the desktop.​
6. Place the shortcut where you like to use it at.​
7. When done, you can delete the System Restore.zip file.​
OPTION TWO
To Manually Create the "System Restore" Shortcut
1. Right click on a empty area of your destop.​
2. Click on New and Shortcut.
3. Copy and paste the location below into the create window. (See screenshot below)​
%SYSTEMROOT%\System32\rstrui.exe
4. Click on the Next button.
5. Type System Restore. (See screenshot below)​
NOTE: You can name this anything like though.​
6. Click on the Finish button.​
  • System Restore.zip
    System Restore.zip
Hi Brink, Very cool tip! I put one on both Admin. and Standard U. accts. They will get used !!! Thanks Loads, Bare Foot Kid ;)
    * BFK Customs *
    Intel C2Q 9550 Yorkfield
    ASUS P5Q Pro
    8GB Dominator 8500C5D
    XFX ATI 1GB 4870 XXX
    Realtek HD 7-1
    1920x1080P & 1920x1200
    Corsair 620HX
    CM Cosmos RC-1000
    Razer Diamondback 3G
    HP Enhansed Multimedia
    18.6Mb/s
    My First Build ;)
Your welcome Bare Foot Kid. Glad that you like it.
