How to Customize the Vista Aurora Screen Saver Settings
By default the Aurora screen saver has no options to set in the Screen Saver Settings window. However, you can customize the Aurora screen saver settings through the registry instead. This will show you how to.
The default location of the Aurora screen saver file is at:
C:\Windows\System32\Aurora.scr.
You will just need to play with the settings and adjust the Value Data (step 8) until you get the desired affect from the selected DWORD Value Name (step 5).
EXAMPLE: Aurora Screen Saver
1. Click on the Download button below to download the file below.
Restore_Default_Aurora.reg
2. Click on Save, and save the .reg file to the Desktop.
3. Right click on the downloaded .reg file and click on Merge.
4. Click on Run, Continue (UAC), Yes, and then OK when prompted.
5. When done, you can delete the downloaded .reg file if you like.
1. Open the Start Menu.
3. Click on Continue in the UAC prompt.
4. In regedit, go to: (See screenshot below)
Code:
HKEY_CURRENT_USER\Software\Microsoft\Windows\Current Version\Screensavers\Aurora
5. In the right pane, right click on a empty area and click on New and DWORD (32-bit) Value. (See screenshot above)
6. Type in a DWORD Value Name you want in the table below and press Enter.
[TABLE=class:-grid,-width:-700][TR][TD]DWORD Value Name
[/TD]
[TD]
Value Data
[/TD]
[TD]
Description
[/TD][/TR]
[TR][TD]
Amplitude
[/TD]
[TD]
500000000 to 2000000000
[/TD]
[TD]
Higher value number for a slower slow motion affect.
[/TD][/TR]
[TR][TD]
Brightness
[/TD]
[TD]
1000000000 to 1050000000
[/TD]
[TD]
Higher value number for brighter affect.
[/TD][/TR]
[TR][TD]
NumLayers
[/TD]
[TD]
1 to 15
[/TD]
[TD]
Number of aurora layers.
[/TD][/TR]
[TR][TD]
Speed
[/TD]
[TD]
1000000000 to 2100000000
[/TD]
[TD]
Higher value number for faster cycling.
[/TD][/TR][/TABLE]
7. Right click on the DWORD Value Name (from step 6) and click on Modify.
8. Dot Decimal, and type in the Value Data you want in the table above and click on OK. (See example screenshot below)
9. Repeat steps 5 to 8 to customize another available DWORD Value Name option.
NOTE: You can add and customize one, a few, or all of the available options if you like (see table below step 6), but only add one instance of each DWORD Value Name in step 5 to prevent problems.
10. Close Regedit when done.
That's it,Shawn
