Enable or Disable Detailed Verbose Logon, Logoff, Startup, and Shutdown Status Messages in Vista and Windows 7
This will allow you to enable or disable displaying status messages that reflect each step in the process of starting, shutting down, logging on, or logging off the computer.This is disabled by default in Vista and Windows 7.
If enabled, you will get more detailed (verbose) status messages than just the normal "Logging On", "Logging Off", or "Shutting Down" messages.
EXAMPLE: Shutdown with one Detailed Status Message step
1. Open the Local Group Policy Editor.
2. In the left pane, click on Computer Configuration, Administrative Templates, and System (See screenshot below)
3. In the right pane, right click on Verbose vs normal status messages and click on Properties. (See screenshot above)
4. To Enable Detailed Status Messages
A) Select (dot) Disabled or Not Configured and click on OK. (See screenshot below step 5A)
B) Go to step 6.
5. To Disable Detailed Status Messages
A) Select (dot) Enabled and click on OK.
6. Close the Local Group Policy Editor window. Your done.
1. To Enable Detailed Status Messages
A) Click on the Download button below to download the file below.
Enable_Detailed_Status_Messages.reg
B) Go to step 3.
2. To Disable Detailed Status Messages
Disable_Detailed_Status_Messages.reg
5. Click on Run, Continue (UAC), Yes, and then OK when prompted.
6. When done, you can delete the downloaded .reg file if you like.
7. Log off, shut down, or log on to see the changes.
NOTE: This option will work for all Vista editions.
1. Open the Start Menu.
3. Click on the Continue button in the UAC prompt.
4. In regedit, go to: (See screenshot below)
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Policies\System
A) In the right pane, right click on a empty area and click on New and DWORD (32-bit) Value. (See screenshot below)
B) Type VerboseStatus and press Enter.
C) Right click on VerboseStatus and click on Modify.
D) Type 1 and click on OK. (See screenshot below)
E) The registry will now look like this. (See screenshot below)
F) Go to step 7.
6. To Enable Detailed Status Messages
A) In the right pane, right click on VerboseStatus and click on Delete. (See screenshot above)
B) Click on Yes to confirm deletion.
7. Close regedit.
8. Log off, shut down, or log on to see the changes.
That's it's,Shawn
Related Tutorials
- How to See Vista Boot Information at Startup
- How to See the About Windows Vista and System Information
- How to See Windows Vista Current License Information
- How to Display Information About Previous Logons During User Logon in Vista
- How to See What the System Uptime is in Vista
- How to Create a Log Off Shortcut in Vista
- How to Create a Restart Computer Shortcut in Vista
- How to Create a Shutdown Computer Shortcut in Vista
