How to Allow or Prevent the Color Scheme to be Changed in Vista
This will show you how to allow or prevent the Color Scheme in the Apearance Settings window to be changed for all users. By default, the color scheme is allowed to be changed.
This is for the Windows Aero (All Vista editions except Home Basic), Windows Vista Standard (Only the Vista Home Basic edition), Windows Vista Basic, Windows Standard, Windows Classic, High Contrast White, High Contrast Black, High Contrast #2, and High Contrast #1 color scheme options depending on your edition of Vista.
EXAMPLE: Color Scheme Set to Allow and Prevent from being Changed
NOTE: For how to change these settings, see: How to Change the Color Scheme in Vista
1. Open the all users, specific users or groups, or all users except administrators Local Group Policy Editor for how you want this policy applied.
2. In the left pane, click on User Configuration, Administrative Templates, Control Panel, Display, and Desktop Themes. (See screenshot below)
3. In the right pane, right click on Prohibit Theme color selection and click on Properties. (See screenshot above)
4. To Allow Color Scheme Change
A) Select (dot) Disabled or Not Configured and click on OK. (See screenshot below step 5A)
B) Go to step 6.
5. To Prevent Color Scheme Change
A) Select (dot) Enabled and click on OK.
6. Close the Local Group Policy Editor window. Your done.
1. To Allow Color Scheme Change
A) Click on the Download button below to download the file below.
Allow_Color_Scheme_Change.reg
B) Go to step 3.
2. To Prevent Color Scheme Change
Prevent_Color_Scheme_Change.reg
5. Click on Run, Continue (UAC), Yes, and then on OK when prompted.
6. When done, you can delete the downloaded .reg file if you like.
1. Open the Start Menu.
3. Click on the Continue button in the UAC prompt.
4. In regedit, go to: (See screenshot below)
NOTE: If System is not here, then right click on Policies and click on New and Key. Type System and press Enter.
HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Policies\System
A) In the right pane, right click on a empty area and click on New and on DWORD (32-bit) Value. (See screenshot above)
B) Type NoColorChoice and press Enter.
C) Right click on NoColorChoice and click on Modify. (See screenshot below)
D) Type 1 and click OK. (See screenshot below)
E) The registry will now look like this. (See screenshot below)
F) Go to step 7.
6. To Allow Color Scheme Change
A) In the right pane, right click on NoColorChoice and click on Delete. (See screenshot above)
B) Click on Yes to confirm deletion.
7. Close regedit.
That's it,Shawn
