Uninstall Device and Device Driver
How to Uninstall a Device and Device Driver in Vista
This will show you how to uninstall a device, a device driver, or both in Vista.
You must be logged on as an administrator to perform these steps
OPTION ONE
Through Programs and Features
NOTE: This will only uninstall the device driver software and not the device itself from Device Manager. You would use this option if you wanted to install another device driver version afterwards for the device.
1. Open the Control Panel (Classic View).​
2. Click on the the Programs and Features icon.​
3. Look to see if the device driver is listed. (See screenshot below step 4)​
A) If it is, then right click on the listed device and click Uninstall, then Yes to confirm.​
NOTE: Sometimes, you will get a notice to restart the computer to finish uninstalling the driver. If you do, then click on Yes to restart the computer when prompted.​
B) If not, then use OPTION TWO below.​
4. Close the Programs and Features window.​
5. If a generic driver for the device is included in Windows, then Windows will automatically install this generic driver for the device if the device is still connected.​
OPTION TWO
Through Device Manager
NOTE: This will allow you to uninstall just the device, or both the device and device driver.
2. Click on the Device Manager icon.​
3. If prompted by UAC, then click on Continue.​
4. Click on the + sign next to the device you want to uninstall to expand it. (see screenshot below step 5)​
5. Right click on the listed device and click on Properties.​
NOTE: You can also click on Uninstall and go to step 8 instead.​
6. Click on the Driver tab. (see screenshot below step 7)​
7. Click on the Uninstall button.​
8. To Uninstall Only the Device
NOTE: This will only uninstall the device and leave the device driver still installed for the device.​
A) Uncheck the Delete the driver software for this device box. (see screenshot below step 9)​
NOTE: If you do not have this option, then only the device will be uninstalled. Go to step 10.​
B) Click on OK.​
NOTE: Sometimes, you may be prompted to restart the computer to finish uninstalling the driver. If you do, then click on Yes to restart the computer.​
C) Go to step 10.​
9. To Uninstall Both the Device and Device Driver
NOTE: This will uninstall both the device and device driver software installed for the device.
A) Check the Delete the driver software for this device box.​
B) Click on OK.​
10. Device Manager will now no longer have the device listed. (see screenshot below)​
11. Close Device Manager. (see screenshot below step 5)​
12. If a generic driver for the device is included in Windows, then Windows will automatically install this generic driver for the device if the device is still connected.​
Brink, just one thing that I have never been able to work out on my own!: If I have an (ATI) graphics card and driver, and I uninstall this graphics device from Device Manager, will I get a black screen, or a Vista default driver?
Thanks so much!
    Dell XPS 420
    Stock Dell 0TP406
    4 gb (DDR2 800) 400MHz
    1600 x 1200 and 1280 x 1204
    Stock PSU - 375W
    Dell XPS 420
    Stock Fan
    Dell Bluetooth
    120 kb/s
Hello Niemiro,
If you uninstall the device (graphics card) in Device Manager, it will just auto detect it again at restart and reinstall it using the latest driver you have installed.
If you uninstall the device and driver, then it will still auto detect and reinstall it, but it will use the default drivers that came with Vista.
Hello Niemiro,
It does help a lot! Thank you so much for taking the time to educate me!
    Dell XPS 420
    Stock Dell 0TP406
    Stock PSU - 375W
    Dell XPS 420
    Stock Fan
    Dell Bluetooth
    120 kb/s
You're most welcome Niemiro. :)
Thanks for the info,
but How do I prevent Vista from automatically installing the generic driver after I uninstall my driver?
I have a sigmatel audio device on a Dell Inspiron 1525 Laptop.
I tried:
1. deleting the Dell/Driver/Audio folder
2. Uninstalling the Sigmatel driver from add/remove programs
3. Uninstalling the driver from device manager.
Everytime I rebooted, vista installed the generic driver and I need a complete uninstall so that I would be able to Install a certain version of sigmatel that has input monitoring.
Hello Moonmadness, and welcome to Vista Forums.
You could set your Windows Update settings to Check for updates but let me choose whether to download and install them. You would have to manually selected and install Windows Updates that you want afterwards every 2nd Tuesday of the month, but you will no longer have drivers automatically installed from Windows Updates anymore.
http://www.vistax64.com/tutorials/120695-windows-update-windows-automatic-updating.html
Hi Shawn,
Thanks for your reply,
Eventually I managed to do what I needed by installing the SigmaTel driver right after uninstalling the vista native driver, that is, without rebooting in between, so Vista didn't get the chance to reinstall it automatically.
This is even easier than what you suggested :-)
but thanks!
That's great news Moonmadness. I'm happy to hear that you got it sorted. :)
