Recycle Bin - Restore
How to Restore the Recycle Bin back to the Desktop in Vista
This will show you how to restore the Recycle Bin back to the desktop if it was deleted by mistake or is missing.
The Recycle Bin usually gets deleted by mistake when you right click on the Recycle Bin and click on Delete instead of Empty Recycle Bin.
  • First, check to make sure that the Recycle Bin was not just moved off-screen by accident.
    • Right click on a empty space on the desktop and click on View and click on Auto Arrange to check it.
  • Second, check to make sure that the desktop icons are not set to hide.
    • Right click on a empty space on the desktop and click on View and click on Show Desktop Icons to check it.
  • If you have more than one monitor, check to make sure that it did not get moved to the other monitor screen by mistake.
EXAMPLE: The Recycle Bin - Full and Empty
1. Right click on a empty area of the desktop and click Personalize.​
2. Click on the Change desktop icons link in the upper left corner. (See screenshot below)​
3. Check the Recycle Bin box. (See screenshot below)​
4. Click on OK.​
still get a message "Recycle Bin on C:\ is corrupted. Do you want to empty the Recycle Bin for this drive?" Dialogue box appears saying Deleting 4 items (91.3MB) When actually there are no files appearing in the Recycle Bin. Under the Heading it says "$Recycle.Bin (C:\$Recycle.Bin) Discovered 0 items (0 bytes).... and the bar showing per cent of completion begins and 1/3 of the way to finiishing another Dialogue box appears that says "the action cannot be completed because the file is open in another program" which there are no other programs running and the next line says "Close the file and try again". There are no files in use to close but the file that is shown in the dailogue box is a Quickbooks file which is a file that resembles no Quickbooks file I have ever seen.
hey brink i deleted the recycle bin and thought that i can bring it back but the recycle bin option is already checked in desktop properties and i cannot get it back| please help!
    Compaq
    intel 965 chipset family
    2 GB DDR 2 SD RAM @ 667 MHz
    On board upto 358 MB RAM
    15"
    160 GB WDC
Hello Dinesh,
See if toggling it on and off may help. Also check the TIP box at the top of this tutorial to see if any of it may apply to you. If all of that fails, try a restart.
You're welcome Adspain, and welcome to Vista Forums.
    gateway/m6881
    3GB
    500GB WD
    logitech
    fios 35MB not!!!!
Hi you all
Here's another nice trick to create the Recycle Bin in a folder of your choice.
First create a new folder... ( Give it a name of your choice )
then add the following string after the given folder name :
.{645FF040-5081-101B-9F08-00AA002F954E}
For example : MyBin.{645FF040-5081-101B-9F08-00AA002F954E}
Note that there's a period (dot or full stop) between MyBin and {645FF040-5081-101B-9F08-00AA002F954E}
When you click this folder ( MyBin ), the Recycle Bin will open.
It also gives you a lot of options in the right click menu which you normally don't have for the Recycle Bin.
Sweet
(You can create as many Recycle Bins at any location of your choice with this operation)
    Acer Aspire 5738G-644G32MN
    Intel Core 2 Duo - clockspeed 2000 MHz
    Acer JV50
    RAM 4 GB - SO-DIMM DDR3
    NVIDIA GeForce - G105M - 512 MB
    1366 x 768 Pixels
    Hitachi HTS543232L9A300 320 GB - Type SATA - Speed 5400 rpm
    Logitech Wireless Mouse M505
    Azerty
    Currently 14.5 MB/Sec which means 1.8 MB/Sec effective
While we're at it, lets have some more fun.
Paste the code below in Notepad, and save it "Save As..." as CreateRbin.vbs
If you click the file CreateRbin.vbs, you can easily create a Recycle Bin.
Code:
RclBn()
Sub RclBn()
On Error Resume Next
Set objNetwork = CreateObject("WScript.Network")
    UsrNm = objNetwork.UserName
Rbn = InputBox _
    ("Hi " & UsrNm & vbCrLf & vbCrLf & _
    "To create the Recycle Bin in this folder," & vbCrLf & _
    "Enter a name like this :    MyBin" & vbCrLf & _
    "Don't use quotes " & "(" & Chr(34) & Chr(34) & ")" & _
    " in the name."& vbCrLf & vbCrLf & _
    "If you want to create the file in another location," & vbCrLf & _
    "then enter the path to the location," & vbCrLf & _
    "where the file should be created." & vbCrLf & _
    "Like this :    C:\Program Files\MyBin" & vbCrLf & _
    "Don't use quotes " & "(" & Chr(34) & Chr(34) & ")" & " in the path.", _
    " Create Recycle Bin",, ,0)
If Rbn = "" Then
    Set Rbn = Nothing
    Set objNetwork = Nothing
    Set UsrNm = Nothing
    WScript.Quit
End If
Set Fso = CreateObject("Scripting.FileSystemObject")
Set StrF = Fso.CreateFolder( Rbn & ".{645FF040-5081-101B-9F08-00AA002F954E}")
If Fso.FolderExists ( Rbn & ".{645FF040-5081-101B-9F08-00AA002F954E}") Then
    CreateObject("WScript.Shell").Popup vbCrLf & "Done", 1, " Check", 4096 + 64
    Set UsrNm = Nothing
    Set Rbn = Nothing
    Set Fso = Nothing
    Set StrF = Nothing
Else
If MsgBox _
    ("Sorry " & UsrNm & vbCrLf & vbCrLf & _
    "The path you've entered does not exist,     " & vbCrLf & _
    "please try again." _
    , 4096 + 48 + vbRetryCancel + vbDefaultButton1, " oops") = 4 Then
    Set UsrNm = Nothing
    Set Rbn = Nothing
    Set Fso = Nothing
    Set StrF = Nothing
    RclBn()
Else
    Set UsrNm = Nothing
    Set Rbn = Nothing
    Set Fso = Nothing
    Set StrF = Nothing
    WScript.Quit
End If
End If
End Sub
It even lets you create a nameless Recycle Bin.
Just type a space,
or when you specify a path, don't type anything after the last backslash.
Like this C:\Program Files\
Sweet
    Acer JV50
    1366 x 768 Pixels
    Azerty
