How to Enable or Disable Lock the Taskbar in Vista
This will show you how to enable or disable the ability to check or uncheck the Lock the Taskbar option for all users on the computer to have the taskbar stay as it was last set to locked or unlocked.
To just lock or unlock the taskbar, see: How to Lock or Unlock the Taskbar in Vista
EXAMPLE: Lock the Taskbar Enabled or Disabled in the Taskbar Context MenuNOTE: Notice that Lock the Taskbar is grayed out when disabled.
EXAMPLE: Lock the Taskbar Enabled or Disabled in Taskbar and Start Menu PropertiesNOTE: Notice that Lock the Taskbar is grayed out when disabled.
1. Open the all users, specific users or groups, or all users except administrators Local Group Policy Editor for how you want this policy applied.
2. In the left pane, click on User Configuration, Administrative Templates, and Start Menu and Taskbar. (See screenshot below)
3. In the right pane, right click on Lock the Taskbar and click on Properties. (See screenshot above)
4. To Enable Lock the Taskbar
A) Dot Disabled or Not Configured and click on OK. (See screenshot below step 5A)
B) Go to step 6.
5. To Disable Lock theTaskbar
A) Dot Enabled and click on OK.
6. Close the Local Group Policy Editor window. Your done.
1. To Enable Lock the Taskbar
A) Click on the Download button below to download the file below.
Enable_Lock_Taskbar.reg
B) Go to step 3.
2. To Disable Lock the Taskbar
Disable_Lock_Taskbar.reg
5. Click on Run, Continue (UAC), Yes, and then OK when prompted.
6. When done, you can delete the downloaded .reg file if you like.
1. Open the Start Menu.
3. Click on the Continue button in the UAC prompt.
4. In regedit, go to: (See screenshot below)
5. To Disable Lock the Taskbar
A) In the right pane, right click on a empty area and click on New and DWORD (32-bit) Value. (See screenshot above)
B) Type LockTaskbar and press Enter.
C) Right click on LockTaskbar and click on Modify. (See screenshot below)
D) Type 1 and click on OK. (See screenshot below)
E) The registry will now look like this. (See screenshot below)
F) Go to step 7.
6. To Enable Lock the Taskbar
A) In the right pane, right click on LockTaskbar and click on Delete. (See screenshot above)
B) Click on Yes to confirm deletion.
7. Close regedit.
That's it,Shawn
Related Tutorials
- How to Use Quick Launch in Vista
- How to Hide or Show a Notification Icon in Vista
- How to Show or Hide All Notification Area System Tray Icons in Vista
- How to Turn Open Window Thumbnail Previews On or Off for the Taskbar in Vista
- How to Enable or Disable the Taskbar Thumbnail Previews in Vista
- How to Turn Group Similar Taskbar Buttons On or Off in Vista
- How to See the Date and Time on the Taskbar in Vista
- How to Add or Remove a Toolbar on the Taskbar in Vista
- How to Enable or Disable the Vista Taskbar Context Menus
- How to Enable or Disable the Taskbar and Start Menu Properties Window in Vista
- How to Lock or Unlock the Taskbar in Vista
- How to Change the Quick Launch Icon Size in Vista
- How to Enable or Disable Taskbar Toolbars in Vista
- How to Enable or Disable Taskbar Always on Top in Vista
- How to Turn Taskbar Auto-hide On or Off in Vista
