How to Enable or Disable the Vista Taskbar Context Menus
This will show you how to Enable or Disable the context (right click) menu for the Start menu and button, Taskbar buttons, and Clock for all users on the computer. By default, these context menus are enabled.
Disabling these context menus does not prevent users from using other methods to issue the commands that appear on these context menus. It just hides and prevents access to the context menus.
EXAMPLE: Start Menu and Button, Taskbar and Taskbar Buttons, and Clock Context Menus
1. Open the all users, specific users or groups, or all users except administrators Local Group Policy Editor for how you want this policy applied.
2. In the left pane, click on User Configuration, Administrative Templates, and Start Menu and Taskbar. (See screenshot below)
3. In the right pane, right click on Remove access to the context menus for the taskbar and click on Properties. (See screenshot above)
4. To Enable Taskbar Context Menus
A) Select (dot) Disabled or Not Configured, then click on OK. (See screenshot below step 5A)
B) Go to step 6.
5. To Disable Taskbar Context Menus
A) Selec (dot) Enabled and click OK.
6. Close the Local Group Policy Editor window. Your done.
1. To Enable Taskbar Context Menus
A) Click on the Download button below to download the file below.
Enable_Taskbar_Context_Menus.reg
B) Go to step 3.
2. To Disable Taskbar Context Menus
Disable_Taskbar_Context_Menus.reg
5. Click on Run, Continue (UAC), Yes, and then OK when prompted.
6. When done, you can delete the downloaded .reg file if you like.
7. Log off and log on, or restart the computer to apply changes.
1. Open the Start Menu.
3. Click on Continue in the UAC prompt.
4. In regedit, go to: (See screenshot below)
A) In the right pane, right click on a empty area and click on New and DWORD (32-bit) Value. (See screenshot above)
B) Type NoTrayContextMenu and press Enter.
C) Right click on NoTrayContextMenu and click on Modify. (See screenshot below)
D) Type 1 and click on OK. (See screenshot below)
E) The registry will now look like this. (See screenshot below)
F) Go to step 7.
6. To Enable Taskbar Context Menus
A) In the right pane, right click on NoTrayContextMenu and click on Delete. (See screenshot above)
B) Click on Yes to confirm deletion.
7. Close regedit.
8. Log off and log on, or restart the computer to apply changes.
That's it,Shawn
Related Tutorials
- How to Customize the Context Menu for the Start Menu in Vista
- How to Turn Group Similar Taskbar Buttons On or Off in Vista
- How to See the Date and Time on the Taskbar in Vista
- How to Add or Remove a Toolbar on the Taskbar in Vista
- How to Enable or Disable the Taskbar Thumbnail Previews in Vista
- How to Lock or Unlock the Taskbar in Vista
- How to Change the Date and Time in Vista
- How to Enable or Disable the Taskbar and Start Menu Properties Window in Vista
- How to Enable or Disable Lock the Taskbar in Vista
- How to Enable or Disable Taskbar Toolbars in Vista
- How to Enable or Disable Adding and Removing Taskbar Toolbars in Vista
- How to Show or Hide Folder Full Path in the Vista Taskbar Buttons
- How to Enable or Disable Taskbar Always on Top in Vista
- How to Turn Taskbar Auto-hide On or Off in Vista
