How to Enable or Disable the Control Panel in Vista and Windows 7
This will show you how to Enable or Disable the Control Panel in all user accounts on the computer.
This will add or remove the Control Panel shortcut icon from the Start menu and Windows Explorer. If a user tries to open the Control Panel while disabled, they will get a Restrictions message. (See example below)
If you did not disable the Control Panel, then it may have been done by some kind of malware or spyware. You should do a complete scan of your computer for a virus and other malware to be safe.
If you have this Control Panel problem here, then see: Microsoft Help and Support: Icons are missing from Control Panel, or you cannot start Control Panel, the Welcome Center, or games in Windows Vista
EXAMPLE: Control Panel Disabled Restrictions Message
1. To Enable Access to the Control Panel
A) Click on the download button below to download the file below.
Enable_Control_Panel.reg
B) Go to step 3.
2. To Disable Access to the Control Panel
Disable_Control_Panel.reg
5. Click on Run, Continue (UAC-Vista) or Yes (UAC-Windows 7), Yes, and then OK when prompted.
6. Log off and log on, or restart the computer to apply the changes.
7. When done, you can delete the downloaded .reg file if you like.
1. Open the all users, specific users or groups, or all users except administrators Local Group Policy Editor for how you want this policy applied.
2. In the left pane, click on User Configuration, Administrative Templates, and Control Panel. (See screenshot below)
3. In the right pane, right click on Prohibit access to the Control Panel and click on Properties. (See screenshot above)
4. To Enable the Control Panel
A) Dot Disabled or Not Configured. (See screenshot below step 6)
B) Go to step 6.
5. To Disable the Control Panel Icon
A) Dot Enabled.
6. Click on OK.
7. Close the Local Group Policy Editor window when done.
1. Open the Start Menu, then type regedit in the search box and press Enter.
2. If prompted by UAC, then click on Continue (Vista) or Yes (Windows 7).
3. In regedit, navigate to the location below. (See screenshot below step 4C)
NOTE: If you do not have Explorer, then right click on Polices and click on New and Key. Type Explorer and press Enter.
4. To Disable Access to the Control Panel
A) In the right pane, right click on a empty area and click on New and DWORD (32-bit) Value.
B) Type NoControlPanel and press Enter.
C) Right click on NoControlPanel and click on Modify.
D) Type 1 and click on OK. (See screenshot below)
E) Go to step 6.
5. To Enable Access to the Control Panel
A) In the right pane, right click on NoControlPanel and click on Delete. (See screenshot below step 4C)
B) Click on Yes to confirm deletion.
C) In regedit, go to: (See screenshot below)
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Policies\Explorer
D) In the right pane, repeat steps 6A and 6B if NoControlPanel is there to.
6. Close regedit.
7. Log off and log on, or restart the computer to apply the changes.
That's it,Shawn
Related Tutorials
- How to Change a Icon in the Control Panel in Vista
- How to Change the Desktop Control Panel Icon in Vista
- How to Only Show Specified Control Panel Icons in Vista
- How to Hide or Show a Control Panel Icon in Vista and Windows 7
- How to Turn Windows Features On or Off in Vista
- How to Create a Power Options Shortcut in Vista
- How to Add or Remove Local Group Policy Editor from the Vista Control Panel
- How to Add or Remove Registry Editor from the Vista Control Panel
- How to Add User Accounts Netplwiz to the Control Panel in Vista
- How to Force Control Panel Home or Classic View in Vista
