Keyboard Input Language
How to Change the Keyboard Input Language in Vista
The keyboard input language is a setting in Vista that controls the language you use to type information on your computer. By default, the language is the same as the one you selected when installing Vista. This will show you how to change and add an additional input language option to choose from.
This does not change the display lanquage in Vista.
2. Click on the Regional and Language Options icon.​
3. Click on the Keyboards and Languages tab. (See screenshot below)​
4. Click on the Change keyboards button.​
5. To Add a Input Language
A) Click on the Add button under the Installed Services section. (See screenshot below)​
6. Select and expand the language you want to add. (See screenshot below)​
A) Expand Keyboad.​
B) Check the input language you want for the keyboard.​
NOTE: Check Show More, if listed, to see the complete list of input languages under the language you want to add.
D) Click on Preview to see what the keyboard layout will look like.​
NOTE: See screenshot below step 8 below.
C) Click on OK.​
7. Click on Apply. (See screenshot below)​
8. To See the Keyboard Layout for a Input Language
A) Highlight the language under the Installed Services section, under Keyboard, and click on Properties. (See screenshot above and below)​
EXAMPLE: United Kingdom.​
B) Click on OK or Cancel to exit this.​
9. To Remove a Input Language
A) Highlight the EN language under the Installed Services section and click on Remove. (See screenshot below step 7)​
B) Click on Apply.​
10. To Select a Default Input Language
NOTE: This will allow you to select between the default input language when Vista was installed and the ones that you added from step 5 above to use to type in.​
A) You have three methods to do this.​
METHOD ONE:
A) Under the Default input language section, click on the drop down menu and select a language.​
B) Click on OK. (See screenshot below step 7)​
METHOD TWO:
A) Press the Left ALT + SHIFT keys to cycle through the listed languages under the Installed Services section.​
NOTE: You can verify the change by method one or three.
METHOD THREE:
A) Click on the language bar icon on the taskbar. (See screenshot below)​
NOTE: You will not see this unless you have more than one default input language added. (Step 5)
B) Click on the language you want as the default input language to check it.​
NOTE: Right click on the language bar icon to adjust the settings for it.​
11. To Organize the Input Languages
A) Highlight the EN language, under the Installed Services section, and click either Move Up or Move Down to change the list order of the language. (See screenshot below step 7)​
B) Click on Apply.​
12. Click on OK when done. (See screenshot below step 7)​
Hi Shawn. I do EXACTLY how you show in your tutorial, but EN or RU (I'm trying to add Russian) doesn't light up here
after I do everything that is written. Is this something wrong with my installation??
Thank You
    Dell Inspiron 518
    Intel Core 2 Duo E7400 Wolfdale 2.8GHz
    Stock board
    SAMSUNG Spinpoint 750GB
    EVGA GeForce 9500 GT 1GB 128-bit GDDR2
    No sound!! (LoL, I have no clue)
    Dell 22" Widescreen
    Western Digital Caviar Blue 640GB
    Hec HP585D 585W ATX12V
    Factory Case from Dell Inspiron 518
    ZALMAN CNPS7700-CU 120mm 2 Ball Cooling Fan
    Cables Unlimited A4Tech Wireless Battery Free Optical Mouse
    A4Tech GKS-26
    Comcast Cable Hi-Speed
Hello Ilya,
If you have the screenshots under steps 6 and 7 set with Russian selected like below, then you should be able to left click on the language bar to be able to select RU.
    Dell Inspiron 518
    Stock board
    Dell 22" Widescreen
    A4Tech GKS-26
The language bar will only display the language that you are currently using. What happens when you left click on EN on the language bar? You should be able to select RU.
Sir, that is EXACTLY what I don't get after I apply all of the settings. I've been using this feature for many years now; I know what I should see on my taskbar. I DO NOT HAVE "EN" or "RU". And the keyboard doesn't switch neither.
    Dell Inspiron 518
    Stock board
    Dell 22" Widescreen
    A4Tech GKS-26
As a test, create a new administrator account and log on to it to see if it works properly in that account instead.
If it does, then copy all of the contents of the old user account's C:\Users\(user-name) folders (including hidden AppData folder) into the corresponding new account's C:\Users\(user-name) folder. After everything checks out ok, you can delete the old user account while logged in the new user account.
Did what you said, this does the same. Doesn't appear nor change.
    Dell Inspiron 518
    Stock board
    Dell 22" Widescreen
    A4Tech GKS-26
Ok. Go ahead and run a sfc /scannow command to see if it may be able to work properly afterwards.
If not, then you can do a repair install without losing anything.
