Yet another update problem
rolandrat
Sometime after 24/11/08 I installed about 4 vista updates, after which boot and shutdown times greatly increased. By which I mean, when you get the green sliding bar when booting, pre-update I would get between 6 and 11 bar progressions, after update I got 50 to 51, before completing the boot.
I've now turned off updates completely and system restored back pre- 24/11/08, and alls well again.
From looking at these forums it seems I am not along with update issues.
I'll leave updates turned off I think.:cool:
    Chillblast
    x9650
    Asus eK
    4gb ddr2
    2xGeForce 9800
    Creative Xfi
    Samsung SyncMaster 245b
    Samsung 1TB HD1030J SATA300
    1000wat
    ThermalTake
    4 extra quiet large fans
    Razor Diamondback
    Saitek
    2gb
Hi rolandrat,
DId this always occur at every bootup after the updates or just the initial times after the updates were installed? Some updates will be configured at bootup and take some time. Do you have SP1 installed at all? If you turn off automatic updates or notification then you should check the update center every once in a while as you might miss important or critical updates.
    Airbot 2.0
    EVGA Nvidia GTX 480 -Fermi
    ASUS Xonar D2X
    1920x1080@60hz
    Corsair HX1000W
    Cooler Master HAF 932
    Logitech Wireless MK700
Hi nim,
Well, it will say what update is critical or important or a security update in the windows update center. You can right click on an update and View Details about the updates and or go to microsoft and research it. Updates really shouldn't be problem makers but some of them might be and usually they will offer suggestions about problems on some at microsoft download center.
    Airbot 2.0
    ASUS Xonar D2X
    1920x1080@60hz
    Corsair HX1000W
Hi airbot,
Thanks for the suggestion. Do you know if 32bit has similar update problem..? Also, do you know if windows defender automatic update causes similar system problems...?
Thanks!
As I do not have 64bit I wouldn't know. As for me, I only had some problems with updates before I installed SP1 then I haven't had any problems after. There are some specific updates that resolve issues with other updates being installed correctly, you should have those offered to you in windows update. Also, there are some updates you are supposed to install before installing SP1. Like I said, review the update details and or go to microsoft and do some research. :)
    Airbot 2.0
    ASUS Xonar D2X
    1920x1080@60hz
    Corsair HX1000W
I would do the automatic updates and restart. What is the rush you are in? I shutdown my computer and walk away. I doubt you can't afford a few minutes of time a few times a month.
    16GB DDR667
    SAS RAID
I use 32 bit and have no problems with updates and that includes Windows Defender ones, my machine is set to update automatically so will do the critical or important ones which are the ones you should do.
    Windows 10 Home
    HP 8312 (Socket FP4)
    Microsoft Optical Wheel Mouse
    62.86Mbps down 18.19Mbps up
