Yellow Triangle System Tray Icon.
Simplex
In my Vista 32 Bit Home Premium there is a yellow triangle icon with an exclamation mark inside it. I don't know what it is and it won't respond if I double click it or mouse over it. Does anyone know what this is?
where exactly ?
    Q6600
    MSI P36 NEO2
    4GB 5-5-5-12
    8800GTS 512Mb Overclocked
    5.1 surround sound
    500Gb Samsung SATAII XP 500GB Samsung SATAII
    1000W CoolerMaster power supply
    CoolerMaster Cosmos 1000 case
    120mm ThermalTake Big Typhoon CPU cooler, 3 x 120mm exhaust
    Wireless Keyboard and mouse 3000
    1TB WD My Book Office edition external drive x 2, Dual layer LG DVD-Rom burner, 15 in 1 card reader Triple boot: XP, Vista Ultimate 64 and Windows 7 Ultimate 64
If it's in your system tray, it means your video driver crashed and recovered.
    Toshiba Satellite X205-S7483
    Intel Centrino Core2 Duo 1.7 GHz
    Toshiba ISRAA 1.0
    2 GB
    nVidia GeForce 8700M GT 256 MB
    RealTek HD Audio
    x2 120 GB
    Logitech Trackman Marble Wheel USB
    Logitech USB
    Millenicom 3G Mobile Broadband @ 1 mbps
    Avast Antivirus Home Edition 4.8.1335, Firefox 3.0.11
That among other things, is one reason, it's basically a hardware failure signal from Device Manager and can be shown for a number of devices.
Open Control Panel - Device Manager and find what item has a yellow with exclamation on it and post here what you find please. Then we can help you find a solution for this, which may be as simple as a reboot in many cases...BTW, have you done a reboot?
    Personal Build
    Intel E6750 Core 2 Duo
    Asus Commando MoBo (P965/ICH8R)
    4G's Crucial Ballistix Tracer DDR2 PC26400 RAM
    BFG 8800GTS OC2 320MB
    Creative Sound Blaster X-FI Platinum FATAL1TY (next)
    2 x 22" w2207 LCD Monitors
    1- 1680 x 1050, 1 - 1920 x 1080
    3 x 500G SATA II WD Caviar HDD's
    EnerMax NoiseTaker II 600W
    NZXT Lexa Classic (modified, dual doored & windowed)
    Zalman 9700 CPU cooler, 4-120mm fans, 1-90mm
    Logitech Optical Trackman trackball
    NZXT Lexa Classic Case, Zalman 9700 CPU Cooler, 2 DVD Burners c/w LightScribe (Sony, TSST), Enermax NoiseTaker II 600W PSU with Custom Chrome cable sleeving, Hauppauge HDTV TV Tuner Card, 5.1 Logitech Z5500 speakers, 15 in 1 Multi-card reader
I have a done a reboot and it seems to have fixed the problem, but its happened like 2-3 times and I wanted to know what was the problem.
In device manager nothing has a yellow exclamation mark except when I reveal hidden devices. Standard PS/2 Keyboard has the yellow exclamation mark.
Hi
Is the exclamation point visible in the tray when you find this PS/2 KB mark in Device Mgr? Or did you find this after the tray notification was removed with the reboot?
If this was after the tray icon was gone and your keyboard still works, that one could be Ok. Like mine, I have 5 keyboard listings but only 1 KBoard...have a look below.
Anyway, if this was found after you cleared the tray icon, it's very possible that this was not the same one that caused your tray notice to show up, so if & when it happens again, check Device Mgr to see what it lists and post that info please.
If your keyboard doesn't work with this exclamation notice now, reinstall the KB drivers and see if that fixes it.
    Personal Build
Thanks, for the info.
Next time I find the yellow icon I'll check it out.
I'm using a wireless keyboard not a PS2 one and it works even when the icon is there/after reboot.
Hey...No prob bud, that's why we're here!!
Yah, I kinda thought the keyboard one was a non issue, or you woulda said sumthin about it eh.
It could very well be that the keyboard one was also the cause of the tray icon notice too. I've noted on other occasions and machines that the tray icon is not always displayed for many device problems, and then next time it is...it seems to be fairly indiscriminate really...like, only when it feels like it kinda deal.
Typical
    Personal Build
