xbox live connection problems
lewismc
ok guys iv done some research and i want to know if everything ive done is correct and if theres some other things i can do. i have got a wireless xbox adapter to my belkin N1 vision router version 1001. please dont tell my to make it LAN because then id have to run a 50m cable through my house so its not an option.
i have pute my xbox in the DMZ that solved NAT problems.
i have tried port forwarding and i think i have done it right not sure. also i did enable QoS but it made my downloads really slow and my internet speed slow.
any thing else you have in mind? here are some pictures.
    COMPAQ Presario CQ60-216TU
    Genuine(R) CPU T1700 @ 1.83GHz 1.83GHz
    2.00 GB RAM
well if it works properly and NAT is open then everything is done fine.
    Fujitsu Computer Siemans SCALEO P
    Intel Celeron 2.80GHz, 2793Mhz, 1 Core, 1 Logical Processor
    Fujitsu Technology Solutions (Can't remember rest)
    2GB 2 x 1GB DDR RAM
    Intel 82915G/GV/910GL Express Chipset Family
    RealTek HD
    LG Flatron M198WDP DTV Monitor
    149GB Internal 465GB External
    Standard SCALEO P
    Air
    ADVENT ADE-EMB1
    GENIUS KKB-2050
    8MB/S AOL Broadband
