frankzappa77
I was wondering if there are other ways of write registry values to the Windows Registry other than importing a .reg file, and running a .bat file containing a 'reg add/delete/etc ...' command.
As of now, the computers at my school contain value of hex 1 for DisableCMD under HKCU\Software\Policies\Microsoft\Windows\System. This means that the command prompt is disabled and batch files are allowed to run. My solution to this was to run a batch file containing the appropriate registry value, overwriting the value of hex 1 to hex 0, to allow full access to the command prompt. I have a feeling that this value might be change to hex 2, meaning no access to cmd and no running of batch files.
I was wondering if a script written in another programming language is able to manipulate the windows registry. And if there is a language capable of doing so, will I be able to run it with its native file extension? (ex: .py, .vbs, etc. as opposed to converting it to .exe)
- Acer Aspire 5630
- Intel Core 2 Duo T5500 1.66GHz 65nm 667MHz FSB 2MB L2
- Acer Grapevine Intel i945GM Chipset
- 2x1GB DDR2 333MHz
- Intel Integrated GMA 950 256MB
- Realtek High Definition Audio
- 15.4" WXGA Acer CrystalBrite LCD 16ms
- 1280x800
- 200GB 5400rpm Toshiba MK2035GSS ATA-7, 250GB 7200rpm Maxtor External USB Hard Drive
