Write an event to the system log will Not stay checked
Hi: I'm having a problem with volmgr error - event id 46. I've checked the forums and checkedthe box for "Write an event to the system log" in the control panel, but it will not stay checked. Is there any way to fix this? Is there something disabled that would cause this? After I check the box and hit OK and the window closes, nothing pops up to ask me to restart the computer or anything and the apply button on the system properties window is grayed out. I even went to cmd and opened control.exe as administrator and checked the box, but that did not work either. Any help you could give would be greatly appreciated.
    Gateway/fx7026
    Intel Core 2 Quad Q9300 / 2.5 GHz
    Intel G33 Express
    4.0 GB
    EVGA GeForce GTX 550 Ti
    Sound card - Integrated
    HP w2408 Wide LCD Monitor
    1280 x 720
    2.0 x 320.0 GB - Standard - Serial ATA-300 - 7200.0 rpm
    400.0 Watt
    Microsoft Wireless Optical Mouse 2.0
    Microsoft Wireless Comfort Keyboard 1.0A
    Cable
    Vista Home Premium 64 bit SP2
    Cyberpower
    Intel Quad CPU Q6700 2.67 GHZ
    NVIDIA 780i
    MSI GTX 560 TI Twin Frozr
    Sound Blaster SB Audigy
    Viewsonic VG2436
    1920x1080p
    Samsung HD 105SI WDC WD20
    Apevia XJupiter
    air
    Logitech MX 600
    Logitech MX 3200
    30 Mbps
I tried that. It didn't work.Thanks though.
    Gateway/fx7026
    Intel G33 Express
    4.0 GB
    1280 x 720
    400.0 Watt
    Cable
Did you try the registry edit?
    Cyberpower
    NVIDIA 780i
    Viewsonic VG2436
    1920x1080p
    Apevia XJupiter
    air
    Logitech MX 600
    Logitech MX 3200
    30 Mbps
