WoW LAG ?? Help pls.
Rodux1
Hello guys I have problem with my MS/PING playing WoW and im very sure that is something about Vista.
Why? becouse i just bought a new pc and i was playing with a btter ping and i had Win XP.
At first i was playing with high latency. But then a friend of mine told me about some kind of trick with some .Net framework stuff he gave me, and my ping went below 100 after i installed it. Like magic.
Now i have Vista 64 in my new pc, and i just cant believe that im playing at 360+ ping Again.
I have been very carefull downloading only what is necessary, I mean, im not installing every crap i see on the inet. Im running task manager and i cant see anything strange or unusual.
Im playing from the same place, same connection, etc.
Can anyone tell me how can i fix this, or make my ping go down??
Thanks a lot. And sorry for my bad english! ;)
    AMD Phenom x3 8450 2.1 @3600
    FOXCONN M61PMV am2+
    4GB DDR2 @800
    XFX Geforce 8600GT 1GB
    Samsung T200 Sapphire WIDE 20* 2ms
    Samsung 320GB 7200 16MB
    Microsoft 3.0 Black
It could be Chavez putting a cap on your bandwidth... ;)
But seriously though, did you try using the same .net framework tweak you used on your XP boot on Vista as well?
    Intel Q9650 w/CM V8 Cooler...
    EVGA GTX260
    Realtek High Def Onboard
    Acer 22" LCD Widescreen
    1680 x 1050
    Thermaltake Speedo Advance
    Air Cooled... See CPU
    Logitech G7
    Logitech G15
    Comcast 6MB Broadband
    Linksys WRT54G router
    HP Compaq Presario/SR5113WM
    AMD Athlon 64 X2 3600+ 1.9Ghz
    Asus M2N68-LA
    PNY Nvidia 8400 GS 256MB
    On board RealTek
    Acer X163W LCD
    1366x768
    Dynex 400w
    Nothin Special
    Stock
    Wireless Logitech LX7
    Comcrap 10mb cable
hahah well i wouldnt be surprise. F**king Chavez is pain in the *ss.
Dude, i havnt tried that but i dont think i could work at all. Another sugestion? :P
    FOXCONN M61PMV am2+
    4GB DDR2 @800
    Microsoft 3.0 Black
    FOXCONN M61PMV am2+
    4GB DDR2 @800
    Microsoft 3.0 Black
You don't install it you just change the settings with the directions in the tutorial.
    Asus M2N68-LA
    On board RealTek
    Acer X163W LCD
    1366x768
    Dynex 400w
    Nothin Special
    Stock
    Comcrap 10mb cable
