Hello,
I have some odd Problems with my WLAN Connection on Vista 64 SP1.
I "loose" my connection to the Internet and IE fails to resolve any DNS querries. But I am still able to use any "open" connection. For example straming audio keeps working or Teamspeak works. (But only for a short while), but they die soon after that. The connection usually recovers after 1-2 minutes.
Sometimes it get stubborn and it stays dead. When I disable the NIC and then reenable it it keeps working. The Problem seems to surface when i have many open connections.
Ipconfig /all:
Windows IP Configuration
Host Name . . . . . . . . . . . . : CleanStart
Primary Dns Suffix . . . . . . . :
Node Type . . . . . . . . . . . . : Hybrid
IP Routing Enabled. . . . . . . . : No
WINS Proxy Enabled. . . . . . . . : No
Wireless LAN adapter Wireless Network Connection 3:
Connection-specific DNS Suffix . :
Description . . . . . . . . . . . : Realtek 8185 Extensible 802.11b/g Wireles
s Device
Physical Address. . . . . . . . . : 00-08-54-88-41-80
DHCP Enabled. . . . . . . . . . . : Yes
Autoconfiguration Enabled . . . . : Yes
IPv4 Address. . . . . . . . . . . : 192.168.178.21(Preferred)
Subnet Mask . . . . . . . . . . . : 255.255.255.0
Lease Obtained. . . . . . . . . . : Friday, January 30, 2009 6:35:05 PM
Lease Expires . . . . . . . . . . : Monday, February 09, 2009 6:35:05 PM
Default Gateway . . . . . . . . . : 192.168.178.1
DHCP Server . . . . . . . . . . . : 192.168.178.1
DNS Servers . . . . . . . . . . . : 192.168.178.1
NetBIOS over Tcpip. . . . . . . . : Enabled
Tunnel adapter Local Area Connection* 6:
Media State . . . . . . . . . . . : Media disconnected
Description . . . . . . . . . . . : isatap.{ECB2AA4E-DD4B-4F5E-85BC-E01302411
579}
Physical Address. . . . . . . . . : 00-00-00-00-00-00-00-E0
DHCP Enabled. . . . . . . . . . . : No
Tunnel adapter Local Area Connection* 11:
Description . . . . . . . . . . . : Teredo Tunneling Pseudo-Interface
Physical Address. . . . . . . . . : 02-00-54-55-4E-01
Ipconfig /all:
s Device
579}
