wireless trouble
Noddsta
hello there ...
my mate has a fujitsu siemens..
she presses her wirless button it dont turn the wirless on..
she presses fn + f1 or somthing it dont work either..
is there any suggestions why this is ?
thanks
Some systems have a button/switch check to see if it is in the on position.
also check Device manager to see if drivers for the wireless card are installed, and functional. If you are using a router with encryption she will have to enter the key to access the network, and check your "Network sharing Center".
    T7600G Core2Duo 2.66 Ghz
    Intel 945PM + ICH7 Chipset
    4GB DDR2 PC2-5300 667MHz
    Mobility Radeon x1900 256MB
    Realtek HD
    WUXGA 17"
    1920X1200
    Wireless Microsoft 3000
    10 mbps/2 mbps
