wireless signal bouncing - causes lag.
TylerC
For quite a while I've been getting terrible lag spikes, its not related to the windows vista wireless problem (Vista-Anti Lag works fine for the 60 second lag) this lag happens when my wireless signal bounces strength (Doesn't matter where I am in my house either) I can have 5 bars and it will drop to 4 for about 30 seconds (during this 30 seconds is a massive amount of lag exceeding 1000ping) then it will go back to 5 bars and it will be fine until it decides to bounce again.
Some of my computer specs:
windows vista home premium x64 (latest updates)
4gbs of ram
AMD Athlon(tm) 64 X2 Dual Core Processor 6000+ (2 CPUs), ~3.0GHz
Wireless Adapter: [Linksys RangePlus Wireless Network USB Adapter] (WUSB100)
Router Access Point: 2wire 3800HGV
ISP: AT&T U-Verse
Some of the things I've tried
-Plugging the wireless adapter into different USB slots
-Moving the router access point around
-Reformatting PC with a clean install
-Windows 7
-Changing the wireless channel (1-11)
-changing the security type (WEP,WPA etc)
-Rebooting the access point
-different wireless adapters
-I have had two different ISP's since this started, just now has it really really began to bother me (I currently have AT&T U-Verse with a 2wire router, before I had yahoo dsl with a WRT54G router as my access point
If anyone can spread some insight on how to fix this I'd really appreciate it.
I have setup a bridged connection with an old WRT54G router using a guide I found in an older thread on here, it seems to be running smooth.
well you changed the os and hardware so the only thing to check out is the router/modem and its connection to the line and possbile you may have radio interference around your house, you should have the option to change to a 2nd channel and increase the signal strenght of the sender if its a good unit.
    home brews
    pc1 msi k7delta, pc2 asus kn79txd evo
    pc1 2gb crucial, pc2 4gb gskill ripjaws
    pc1 bfg 7800gs, pc2 shapphire 5770 vapor-x
    onboard
    corsair hx
    jeantech phong
    pc1, handmade waterblocks,passive cooling, pc2 corsair h50
    logictech mx510s wired
