wireless sharing
say I have thee computers on a network. Two of them are wired directly into the wireless router and the third is connected wirelessly. Will I be able to access the wireless computer through the network like I can the two that are directly connected to the router. Will computer 1 be able to look at computer 3 shared files even though it's not connected directly to the network. Please forgive the crudeness of the questions, as I am a newbie to the networking seen. I am just thinking down the road a bit, as the wife will be getting a laptop w/built in wireless after the first of the year. I will have to get a new wireless router as well. Any info and input would be greatly appreciated.
    Self built
    AMD Athlon 64x2 6000+ 3.0ghz
    Asus M4N78 Pro
    3Gb PC2-5300 DDR2 @ 667mhz
    VIA HD Audio
    OEM HP
    OEM HP
Yes you will be able to connect to the wireless 1 cause its on the same network just not wired.
    HP Compaq Presario/SR5113WM
    AMD Athlon 64 X2 3600+ 1.9Ghz
    Asus M2N68-LA
    PNY Nvidia 8400 GS 256MB
    On board RealTek
    Acer X163W LCD
    1366x768
    Dynex 400w
    Nothin Special
    Stock
    Wireless Logitech LX7
    Comcrap 10mb cable
Thanks.
    Self built
    Asus M4N78 Pro
    VIA HD Audio
    OEM HP
    OEM HP
