Wireless Problem
are you changing you C: drive? is the connection wired or wireless? my guess is software related.
    AMD Phenom ii 940 - 3.60GHz
    ASUS M3A79-T Deluxe
    Kingston HyperX 2x2GB 1066MHz 4096MB
    4870 1GB
    N/A
    Viewsonix VX2240w
    1680 x 1050
    Western Digital Caviar Black 1TB 7200rpm
    Corsair AX850
    Coolermaster HAF 932
    Scythe Mugen 2 rev.b
    Logitech G500
    Das Keyboard Silent Professional
    iunno.
My system is Vista on a laptop, I changed my sata HDD to a larger capacity one its then that my NETGEAR connection does not happen.
If I change the HDD back then the wireless connection is fine.
Hope this helps
Bob
