Wireless Network issues
Lazere
After some searching, I'm coming up with nothing to help me with this problem, so I thought you fine folks may be able to.
I set up a new Cisco router here, and after I got it to play nice with the modem and got the wireless set up, my Vista machine could not connect to the internet through the wireless. Through ethernet it works fine. The XP machine connects fine. The Vista machine will connect to the network but has local access only and will not identify it. It labels it as unidentified network and calls it a public network. I tried changing the settings to private, but it just resets it afterward. I've tried restoring Windows to before I set up the network, to no avail. Deleting and re-creating the connection produces similar results. I've reinstalled drivers, so it's not an issue there. Also, it's not in the card itself as it works fine in Linux on the same machine.
I've got a HP Pavilion dv6000 running Vista Home Premium 32bit.
Any Ideas?
Welcome Lazere,
Sorry it took so long to get to your post , For starters, have you set the wireless config up while connected hardwire? Sometimes, the config. did not get set correctly. Retry and post back results so that i or others will know where we stand on correcting this issue.
    Emachine ET 1161-05
    AMD Athlon 64 LE-1640
    1280x768 pixels
    ST316081 5AS SCSI Disk Device
    Tower
    Fan Speed 1247 RPM
    PS/2 Compatible Mouse
