Any got experience of wireless N dongle that works good in Vista 64?
I want it for my htpc. I have a D-link DI-855 router.
OS: Win Vista 64 Ultimate
hmm dunno mate, but my motherboard has built in wireless (B/G/N) and that works just fine for me.
I would suggest when you look for USB wireless adapters (I assume that's what your looking for) to check for "works with windows vista" or "vista certified" to be sure.
Personally, if I were you, I would buy a new motherboard with wireless automatically built in, that a way you get some increased power and you have your card.
Ok, I found this one for you, USB so its external and its fairly cheap. Not sure if newegg ships to Sweden (pretty sure they do) but if they do, this is the place to shop for anything tech.
Rosewill RNX-N100 IEEE 802.11b/g/n USB2.0 Wireless-N 2.0 Dongle
Newegg.com - Rosewill RNX-N100 IEEE 802.11b/g/n USB2.0 Wireless-N 2.0 Dongle (1T2R) Up to 150Mbps Data Rates/ WPA/WPA2 (AES, 64,128-WEP with shared-key authentication) Cisco CCS V1.0, V2.0 and V3.0 compliant/ Vista
Hope you can find what you are looking for,
Scott
