Wireless Internet Connection Problems
cromartie
Hello all,
I'm wondering if you could help me with my wireless dilemma. My computer is running Windows Vista Home Premium 32 bit, service pack 1. I have a DLink wireless router, model WBR-1310, hardware version B1, firmware version 2.02. The issue I have is my internet connection will randomly go away (the globe will disappear and my network will go local only). This can be while I'm in the middle of doing something online, or sometimes when I get back to the computer from being away for a few hours the connection is gone. I'll have to randomly disconnect/reconnect the connection to the router to reestablish my internet. I've disabled all sleep modes/screen savers/etc. I just want to keep this connection live 24/7.
I would like to know if there is any way to fix this so that my connection becomes more stable.
    Dell Inspiron 1545
    Intel Pentium Dual CPU T3400 2.16 GHz
    3.00 GB
    Roadrunner cable modem / DLink wireless router
Hello all,
Have you tried contacting your ISP? The modem itself or the ISP could be the problem
    Athlon 250 @ 3Ghz
    ECS 6100pm
    2GB DDR2
    9800gt Inno3d Green
    1366 x 768
Problem doesn't happen on my HP laptop that is connected to the Internet. Just this Dell.
    Dell Inspiron 1545
    3.00 GB
Anyone? It keeps doing it and I don't know why.
    Dell Inspiron 1545
    3.00 GB
hello:
---you may try this---log in to the 'router' configuration and check that the dhcp lease time is set to 28 days---(shorter times will cut off cycles)---also try moving it around--- it should be set high---clear of obstructions--- well ventilated---
---if all else fails---phone the 1-800-number---(I did that when MY router did not work - we set it up step-by-step, over the phone) - works now!---yeay---
---please post your results---thank you---
peace
    eMachines D620 (laptop)
    AMD Athlon Processor 2650e 1.60GHz
    ACPI x86-based PC
    (RAM) 1.00GB
    Internal DAC (400MHz) - memory: 382 MB
    Realtek High Def Audio
    ATI Radeon X1250 - 14"
    1280 x 800 (60Hz)
    ST9160310AS ATA Device
    Stealth~graphite
    Synaptics PS/2 Port Touchpad + Microsoft Optical Mouse 500
    Launch Manager Version 2.0.02
    Cable/wireless-router
    NO WEBCAM - (privacy)
