I have been on the phone collectively for 6 hours with AT&T as well as had a technician out here to look at this problem. I have a new wireless router box.
The whole At&T system went down briefly (tvs and all). When it booted back up my computer wouldn't recognize the wireless network.
After getting a new box, it will now recognize the wireless network in my home. It says I am connected to the network with excellent strength but I still cannot get online.
My desktop works fine and I plugged the ethernet cable into my computer and it still won't get online being hardwired to the router.
My firewalls are turned off.
I have run an ipconfig with the following message:
Wireless LAN adapter Wireless Network Connection:
Connection-specific DNS Suffix . :
Autoconfiguration IPv4 Address . : 169.254.41.21
Subnet Mask . . . . . . . . . : 255.255.0.0
Default Gateway . . . . . . . :
Ethernet adapter Local Area Connection:
Media State . . . . . . . . . : Media disconnected
Tunnel adapter Local Area Connection*6:
Connection-specific DNS Suffix. :
(And this last one "Tunnel adapter Local Area Connections repeats using the numbers 7, 12, and 13 with the same message)
Someone suggested I run an sfc/scnnow
The following message came up:
Windows Resource Protection found corrupt files but was unable to fix some of them.
Details are included in the CBS.Log windir\Logs\CBS\CBS.log For example C:\Windows\Logs\CBS\CBS.log
What do I do now? And are there any other suggestions?
Of course my warranty for this computer ran out last month and I now can not get anyone to help. The Toshiba line is of no help unless you are a complete computer-idiot. Any help would be splendid! Thanks!
- Toshiba a205 S5843
- Pentium Dual Core Inside
