Wireless but no ethernet
bmeng
So my wireless works well and fine, but the only problem is is that it disconnects time from time and i'm trying to download a 15 gb file that has no resuming capabilities. I want to use my ethernet connection rather than my wireless, but the ethernet (local area connection) isn't showing when I go to Control Panel/Network and Sharing Center/Manage Network Connections. I only see Wireless Network Connection. I have a router and a modem. the router is a linksys cisco. And my cable modem is linksys wrt45 or something. How can I fix this? My other two computers are using the ethernet cables fine.
    Home Grown Desktop
    Intel(R) Core(TM)2 CPU 6600 @ 2.40GHz
    ASUS P5B-E
    3006 MB
    NVIDIA GeForce 8400 GS 512MB
    Motherboard - SoundMax
    ViewSonic VX2235wm / Dell 17" Generic PnP Anolog
    1680 x 1050 x 4294967296 colors / 1024 x 768
    3 x ST3250620AS 250GB SATA IDE 1 x WDC WD1200JD-00GBB0 120 GB SATA IDE
    Enerrmax 535W All-in-one SLI 20/24+6+
    Antec Sonata
    Antec 12cm SmartCool
    Logitech MX100 Laser
    Logitech LX710
    Bell Canada DSL 12MBps (supposedly)
    2 x HP Pavilion 9700v Laptops
Have you guys tried re-installing the drivers?
    HP Pavilion Elite
    Some Amount of Motherness
    6.O GB RAM
    Some Amount of Soundness
    1440x900 & 1440x900
    WD Caviar Blue 500GB
    Some Amount of Voltageness
    Hp Pavilion Elite Case
    Some Amount of Coolingness
    HP: M/N:M-SBQ133
    HP: Model Number: KB0911
    Comcast: 20 MB/S
