wired or wireless??
rickory
Junior
A few network questions ....
1. Is it better to be hard wired then wireless?? I get 300mb wireless n @ 2.4ghz and 100mb wired.I'm cunfused!!!
2.What is the advantage of duel channel 5mhz and 2.4mhz?? I get only fair coverage @5hmz and excellent coverage at 2.4mhz. I tried all the various settings Fair is the best I get.Did I waste my money??
My tv is hard wired...Any advantage to wireless @ 5 Mhz even at Fair signal? I get 125mb with a fair signal.
I think the consensus is that hardwiring by CAT5 is the best for HD video such as blu-ray and AVCHD. If you don't want to string the wire, then you have to live with what you get.
Look at this for a discussion of the dual channel 5 Mhz-
New 802.11n Routers: The Best Wi-Fi Yet | PCWorld
    Vista Home Premium 64 bit SP2
    Cyberpower
    Intel Quad CPU Q6700 2.67 GHZ
    NVIDIA 780i
    MSI GTX 560 TI Twin Frozr
    Sound Blaster SB Audigy
    Viewsonic VG2436
    1920x1080p
    Samsung HD 105SI WDC WD20
    Apevia XJupiter
    air
    Logitech MX 600
    Logitech MX 3200
    30 Mbps
most electronics (microwaves cordless phones etc) use the 2.4ghz band and causes interference with wifi signals. 5GHz is not used by a range of electronics so less interference. 300mb is the advertised speed. the actuall speed is quite lower. BUT it should be slightly faster than 100mb wired. 1000mb (gigabit ethernet) is a different story. hope i helped in some way
    Custom Gaming Rig 780G
    AMG Athlon II X2 255 3.8/2MB/2500MHz 45nm AM3
    Gigabyte GA-MA78LMT-S2 AM3, Core Boost, Ultra Durable 3
    2X 4GB Kingston DDR3 1066MHz @ 1666MHz Dual Channel
    HIS HD Radeon 7770 GHz Edition iCooler Core: 1000MHz
    Realtek HD Audio
    Dell E2311H DVI/VGA 5ms response, Full HD
    1920x1080 @ 60Hz
    320GB Seagate Barracuda 7200.02 SATA II
    Cooler Master Extreme Power Plus 700w
    Lian-Li PC-6010 With Side Window
    Aywun A4 80mm fan
    Logitech K120 Wired Mouse
    Logitech K120 Wired Keyboard
    802.11B/G/N 17Mb/s
    AMD Catalyst 12.6 Thomson A/B/G/N Router LiteON CD/DVD Player GAME PERFORMANCE: Battlefield 3: 41 FPS High 1x AA @ 1280x720 Mass Effect 2 and 3: 60 FPS Highest 4x AA @ 1920x1080 Counter Strike Source (and other Valve games): 300 FPS (max FPS in game) Highest settings 8x AA 16x AF @ 1920x1080!!!
