winload.exe problem
inkystinky
Ok, my computer has been to alot last three days. First I came home, turned on the computer, and zomg! Blue screen at log in. That freaked me out.
I tried restarting it, but the screen was just completly black when it came to log in everytime. So I then started trying to fix it. Did all sorts of checks, but nothing worked.
Ended up reinstalling vista, but keeping my old files.
Then it worked for an hour or so. Next morning, when I started it, this came up: "File:Windows/system32/winload.exe It couldn't be loaded because it's missing or is broken".
It says I should put the vista installation disc inside, then repair it, but it doesn't "notice" that I've put the cd inside. It doesnt seem like it's being detected.
Now how on earth can I fix this?
    Core 2 Duo 2.40Gh'z
    300gb
    9600m GT
Hello inkystinky,
You will need to go to your Bios (press "del" at bootup), and set the boot order.
Set it so that the 1st boot device is the DVD drive .
Reboot and boot from disc when you get the prompt.
Good luck and post your results.
    Self Build
    Asus P5Q Premium
    2 x ASUS EAH 4870 X 2 (Quad)
    Supreme FX 2
    CoolerMaster 1000
    Logitech G5
    Logitech G15
    20Mbps
ok so I did everything you said, managed to reinstall everything and it was up working again. I started reinstalling stuff, then all the suddon: BLUE SCREEN AGAIN!
There must be something seriously wrong with the computer?
    Core 2 Duo 2.40Gh'z
    300gb
    9600m GT
Could you fill out your system specs, and what is it you are installing when it blue screens ?.
It could be something as simple as a driver, it doesn't mean your PC is about to die.
Don't forget to change your Bios back to default when you have finished.
    Self Build
    Asus P5Q Premium
    Supreme FX 2
    CoolerMaster 1000
    Logitech G5
    Logitech G15
    20Mbps
9600M GT
2.4 Gh'z core 2 duo
4GB RAM
What else is there to add? (THe computer just keeps crashing, so can't check :P )
And I was installing the DSL when it crashed (I apperantly have to do that to connect to internet) Then I managed to restart the computer, but seconds later it crashed. (And I wasn't doing anything).
So I'm not sure what the problem is. Next time I'll read the error message if there is one.
I got the blue screen again, but it was up for 0.5seconds. No chance of reading what it says.
    Core 2 Duo 2.40Gh'z
    300gb
    9600m GT
9600M GT
2.4 Gh'z core 2 duo
4GB RAM
Is
could you go into c:\windows\minidump, zip the dump file (*.dmp) and upload it to us so that we can take a look. If you cant find it in minidump search for *.dmp
Ken
    Dell Inspiron E 1405
    [email protected]
    4 gigs
    integrated intel 945
    integrated
    300 gig internal
    10 down 1.5 up
9600M GT
2.4 Gh'z core 2 duo
4GB RAM
Is
Ken
Can't seem to find it.
    Core 2 Duo 2.40Gh'z
    300gb
    9600m GT
Search for .dmp files by pressing F3 to open a searh window and upload them or take a look at the guide in my sig. You could also check the advanced system properties link to determine where the files are stored.
    Sony Vaio Z46GDU
    6GB DDR3 1066MHz SDRAM
    13.1" WXGA True Colour Tough
    1600x900
    320GB SATA 7200RPM
    1MB/s
inkystinky did you get this sorted ?.
    Self Build
    Asus P5Q Premium
    Supreme FX 2
    CoolerMaster 1000
    Logitech G5
    Logitech G15
    20Mbps
Nope. I can't seem to fix it. I think I'll send it back to where I bought it, and get them to fix it... Thanks anyways though.
    Core 2 Duo 2.40Gh'z
    300gb
    9600m GT
