WinDVD and PowerDVD on same machine
JWhipple
Back in my XP and Win2k days I learned quickly that having both WinDVD and PowerDVD on the same machine caused more problems than it was worth.
These days I am running a Dell Studio 17 laptop with Vista Ultimate on it. The Dell pre-loaded DVD apps (Which are based on WinDVD) work ok, but I'd like to have PowerDVD installed as well.
Can anyone advise if having both PowerDVD and WinDVD on Vista will cause issues?
Thanks!
    AMD Athlon 64x2 3800+ (Socket 939)
    MSI K8N SLI
    2GB Corsair DDR in dual channel mode
    2x BFG Geforce 7600GT in SLI mode
    Soundblaster Audigy 2
    Big ol' 21 inch Gateway LCD monitor
    160GB SATA1 (Western Digital) 500GB USB External (Western Digital)
    600 Watt BFG
    Logitech G7
    Logitech G15
Hi JWhipple,
I haven't tried this in Vista as I use the built-in support that is available in Ultimate to play DVDs. I have, however, used both in XP without problems. What you could do is to try it out to see what happens (create a restore point first, then you have something to go back to if it doesn't work).
Just curious as to why Dell chose to include DVD playback software when Vista Ultimate already has support for this media built-in. The only reason that I might opt for one of these programs is if I decide in future to upgrade to HD or BluRay and I find that I need one of them in order to decode the disk content (assuming, of course, that Vista itself is unable to do so).
    Dwarf Dwf/11/2012 r09/2013
    ASRock Z77 Extreme4-M
    ViewSonic VA1912w Widescreen
    Gigabyte IF233
My reason for wanting to have PowerDVD is that you can specify a folder to play the DVD from instead of from the DVD drive. Since I travel with my PC I tend to copy the contents of a few DVDs to the hard drive before each trip so I can have something to watch without bringing the discs. . I'd like to be able to do this on the new laptop.
If there is a way to play a DVD from a folder in WMP or WMC, please, let me know !
    MSI K8N SLI
    600 Watt BFG
    Logitech G7
    Logitech G15
