Window Vista Sound
gabby13
Hi Im trying to find out if my windows vista pc has a build-in microphone. If so how do i acess it and return it on. Any answer will be a big help!! Thank You!:D
What is the make and model number of your computer please.
    Lenovo Thinkpad T400
    LENOVO 64734VM
    Conexant 20561 SmartAudio HD
    15 inch
    Medium for New Zealand
Welcome to the Vista Forums,
Please note Windows Vista is an operating system, and it falls under the category of software. A microphone is a piece of Hardware.
You should be able to find out if your PC has a microphone by checking the specifications. This can be found either with the literature that came with your PC, on the side of box, or on the PC's manufacturer website.
    AMD/GIGABYTE
    AMD Athlon(tm) 64 X2 Dual Core Processor 6000+ (2 CPUs), ~3.
    Gigabyte GA-M57SLI-S4 (rev. 2.0)
    2048MB RAM
    NVIDIA GeForce 8600 GT
    SyncMaster T220/T220G,SyncMaster Magic T220/T220G(Digital)
    1680 by 1050 pixels
    Seagate ST310003 40AS SCSI Disk Device Western Digital WDC WD50 00AAJS-00YFA SCSI Disk Device
    Thermaltake 500W
    VERY FAST>>>>!!!!
    Optiarc DVD RW AD-7191S SCSI CdRom Device
Hi gabby13 and welcome to Vista Forums :party:
If your computer is a laptop or netbook, then it will have a built-in microphone. If not, then you will need an external microphone to plug in (this will also work with a laptop/netbook as well).
    Dwarf Dwf/11/2012 r09/2013
    ASRock Z77 Extreme4-M
    ViewSonic VA1912w Widescreen
    Gigabyte IF233
