Will not reboot; says cannot detect hard drive
arubalover
I have a Dell Inspiron E1705 with Vista Home Premium 32bit. My computer has been shutting down without my doing anything. When I try to reboot, it says that it cannot detect my hard drive and my computer will not start up again. HELP!!!! Thanks
Hello arubalover,
Go in to the Bios and see if the HDD is being recognised there.
Take a look and post your results, good luck.
    Self Build
    Asus P5Q Premium
    2 x ASUS EAH 4870 X 2 (Quad)
    Supreme FX 2
    CoolerMaster 1000
    Logitech G5
    Logitech G15
    20Mbps
Depending on you PC, either F2 or delete should get you there.
    Self Build
    Asus P5Q Premium
    Supreme FX 2
    CoolerMaster 1000
    Logitech G5
    Logitech G15
    20Mbps
Here is a link to the manuals for your laptop: Documentation
Having had a quick read through these, the key required to enter setup is Del. Documentation
Check that your HDD is detected. Also, check the time and date to ensure that it is correct. If the time and date is incorrect, or if they reset themselves then it could be the CMOS battery is failing and needs replacement. See Documentation and in particular Documentation
    Dwarf Dwf/11/2012 r09/2013
    ASRock Z77 Extreme4-M
    ViewSonic VA1912w Widescreen
    Gigabyte IF233
Adding on to what above poster said - You need to repeatedly press DEL immediately after turning the computer on. You should hear a beep and then you'll be in BIOS Setup Utility.
    Self-Built
    AMD PHENOM X4 9600 BE 2.3GHZ @ 2.46GHZ
    TA790GX 128M AM2+
    8GB OCZ PC6400 800MHZ DDR2 RAM
    NVIDIA GTS 250 1GB VRAM
    SB5120 24-BIT 7.1
    AOC 2330V 23" LCD
    1920x1080
    250GB SEAGATE HDD
    650W
    GENERIC
    3 120MM FANS
    MS WIRELESS DESKTOP 3000
    6MB/s
    Main Machine. Just upgraded my RAM to 8GB. Next task will be to get a new processor for this machine ( 9650 was for my secondary machine )
